does this all sound like it'll work?
Old Dec 25, 2004 | 07:15 PM
Tim Hunsinger's Avatar
Car: 91 RS,
Engine: 406ci
Axle/Gears: 2.77 9 bolt
I am going to rebuild a 3.4 motor from a 94 camaro for my '91. If I use FWD aluminum heads, the FWD intake with top spun 180* and FWD pistons I should be okay, right??
1. Are the FWD pistons okay to use on the RWD rods?
2. What FWD intakes are best to use for this and fit '91 throttle body?
3. Cam/lifters/push rods will need to be from FWD motor?
thanks for any input.
Old Dec 25, 2004 | 08:11 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
As for intake, It will need to be a later model, say 94'ish grand prix??
You will have to use the FWD TB also, cant use the camaro one. You will have to custom burn a chip also, or use the full FWD wireharness and ecm.
Pushrods, rockers, fwd.
Cam, any you want for a RWD setup.
Old Jan 5, 2005 | 05:55 AM
Car: 91 RS,
Engine: 406ci
I don't know much about chips. Why would I need a different one? What would happen if I kept stock chip in it?
Frozer!!!
Jan 19, 2024 04:55 PM
db057
Aug 22, 2015 08:17 PM
midias
Aug 22, 2015 01:42 AM
92camaroJoe
Aug 13, 2015 06:07 AM
mustangman65_79
Aug 8, 2015 12:07 PM
