Temp gauge marks
Old Jan 10, 2005 | 01:59 PM
Buck89RS's Avatar
Car: 1989 RS
Engine: 2.8L MPFI Bored 30 over (Rebuilt DEC 2004)
Transmission: 5 - SPD With 3.42 open rear end
Temp gauge marks
The first mark is 100* F second mark is a line and the third is 220* F. My car runs at the line mark. Any ideas as to what temp this is? Thanks
-Buck
Old Jan 10, 2005 | 02:10 PM
V8 Slayer's Avatar
Car: 91 Firebird
Engine: 3.1 V6
Transmission: TH-700-R4
190-195..
Old Jan 10, 2005 | 05:29 PM
Nocturnall's Avatar
Car: 91 Firebird
Engine: 191ci 6cyl
that line is halfway if I'm not mistaken. Mine runs around there and mine runs cold, probably closer to 160 - 170. My fan is wired to a switch so when I turn it on I leave it on till it hits that line. Probably not the best method but I got adhd or something.
Old Jan 11, 2005 | 08:14 AM
Buck89RS's Avatar
Car: 1989 RS
I have a fan switch also and i dont let my engine get to far above that line also. Heat kills new engines. I have a 180* t-stat so when the gauge goes a little above that line my t-stat is almost ready to open and when it does the temp drops back down below that line, then it hovers just a tick above or below that line under normal running condtions. With it being in the 60's and 40's around here I have not had to turn it on yet.
-Buck
Old Jan 11, 2005 | 06:04 PM
Nocturnall's Avatar
Car: 91 Firebird
Engine: 191ci 6cyl
I stick with the stock thermostat because it get's below 0 here, usually around 10 during the winter.
Bubbajones_ya
Jul 6, 2024 08:32 PM
codeysabatini
Nov 10, 2015 04:07 PM
wisemanz28
Sep 20, 2015 01:26 PM
codeysabatini
Sep 20, 2015 11:36 AM
corey8084
Sep 17, 2015 02:56 PM
