cylinder heads
Old Feb 20, 2005 | 08:51 AM
91greenbird's Avatar
Car: 2012 Ram express
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
cylinder heads
i have a oppurtunity to buy aluminum cylinder heads. should i buy them, are they worth it, how much more hp will i get from these heads over stock heads?
cylinder heads
Old Feb 20, 2005 | 10:16 AM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
if you lan on buying a fwd 2.8~3.4 gen II or III, then yes, go for it. If you plan on slapping these bad boys on your gen I .....
search please. these are for fwd engnes. those are the 10048649 Aluminum Cylinder Head
from http://www.gmgoodwrench.com/perfpart...299&section=ep
Old Feb 20, 2005 | 12:03 PM
Doward's Avatar
Car: 1988 Chevy Camaro Hardtop
Engine: Turbocharged/Intercooled 3.1
Transmission: World Class T5 5 Speed
In order to put the FWD heads on the RWD block, you will need custom intake work, and FWD pistons
Old Feb 20, 2005 | 12:28 PM
Engine: 5.7 / 7.4
and fwd intake. goto firebirdv6.com, do a search for russel. HE did the 3X00 swap/mod on his car. And you think I had to do alot to get the 3800 in my ride
Old Feb 20, 2005 | 03:27 PM
Engine: 5.7 hemi
Transmission: auto
Axle/Gears: 3.55
heads
if there fwd heads then im not getting them. Thanks for the help
Old Feb 20, 2005 | 11:24 PM
oil pan 4's Avatar
Car: 89 Firebird
Oh, but they are FWD heads.
A lot of trouble, unless your into that kind of thing.
Cornholio7979
Sep 20, 2018 02:31 AM
Chuck84TA
Jul 15, 2016 09:05 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
NinjaNife
Aug 23, 2015 11:49 AM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
