Code 34-MAF Sensor
Car: 89 Camaro RS
Engine: 2.8
Code 34-MAF Sensor
The service engine soon light on my wife's 89 RS 2.8 has been coming on every now and again for about a month.It's maybe come on 3 or 4 times.So I did a tune up on it.Oil change,air filters,spark plugs,fuel filter,cap and rotor.Light just came on again today and after searching this site I did the paper clip trick and pulled a code 34.I'm not going to have time to work on it till the weekend so my question is what can happen over the next 4 or 5 days with leaving things as they are?
Car: '86 Camaro SC, '16 QX60
Engine: 2.8 V6 POWER, 3.5L V6 N/A
Transmission: T-5, CVT
Nothing. Your engine will just fill in the information gaps missing from the MAF and keep running. Although it would be wise to fix it. When I finally fixed my MAF problem, my backfire went away and I regained some power. Check all the connections and the relay (relay should be located by the battery, at least it is on my '86) before you replace the MAF.
Car: 1985 Z28
Engine: 305 LG4
I suggest you do NOT get a remanufactued one. The first one I got went bad in a month. I'm on the second one and even it isn't very good. That reminds me... was going to call GM today about a new one....
BumpaD82
Feb 26, 2016 02:57 PM
MikkoV
Sep 9, 2015 04:25 PM
