3.1 egr
Old Mar 14, 2005 | 10:17 AM
GreyFox's Avatar
Car: 1991 Firebird
Engine: V6
Transmission: ATOD
3.1 egr
how in the world do i diag my digital egr all the haynes manual says is TAKE IT IN, no thanks i'm pretty sure its bad but before i spend $150 for one i want to make darn sure
Old Mar 14, 2005 | 09:37 PM
FirebirdNYC's Avatar
Car: 1990 firebird
Engine: 3.1 v6
are u getting a code? welcome to world code 32(?), i used to get it all the time on the highway, replaced it with a used one (ha) stil lthe same...then it just decided to stop giving me a code 32..
Old Mar 14, 2005 | 10:11 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
gm repair manual even says no testing, no service required. I boght a 200 bux one, it lasted about 6 months, exchanged it under warrany. that one blew a few months outta warranty.
So now I get the code daily. I blow it off, im not paying that for it.
Old Mar 15, 2005 | 02:26 AM
85berlinetta2.8's Avatar
Car: IROC Z
Engine: 5.7
mine was fixed by simply cleaning the plunger, and repairing the tubes. i just took them off one at a time so i knew where they went back, and blew throught them to get the crap out, and to see if there was any leaks.
i also cleaned that crinkle cut french fry looking tube that goes back to the intake
Old Mar 15, 2005 | 05:48 PM
Car: 1990 firebird
Engine: 3.1 v6
i should give that a try
Old Mar 15, 2005 | 06:12 PM
Car: IROC Z
Engine: 5.7
theres also an egr solonoid there.
those can be had for free at the wreckers if the problem persists.
dont forget to clear the code after you fix it for a test run
Old Mar 15, 2005 | 08:43 PM
Dale's Avatar
Engine: 350 S-TPI
Only the older UFO style egr's have a solonoid. The 3.1 digital ones are just that, all digital.
Old Mar 16, 2005 | 09:41 AM
GreyFox's Avatar
Car: 1991 Firebird
Engine: V6
Transmission: ATOD
funny thing is last night is when i started to get a code haven't had a chance to check it but by my haynes man and some trouble shooting corssreferenceing it leads to the EGR so i'll clean it up and see what happens, thanx guys
Old Mar 22, 2005 | 10:39 AM
GreyFox's Avatar
Car: 1991 Firebird
Engine: V6
Transmission: ATOD
bad news i didn't get a code 32 but i did get a code 22 which doesn't make sense because that to my knowledge wouldn't make the car backfire at all and espically since i just replaced it about 6 months ago
oh yea and also i have a slightly modified chip in my car (bought it like that) not sure what exactly was done with it, now is this the same chip that would be replaced if i replaced my ECU or ECM because i like the performance that the chip gives the car and i don't want to lose it
HoosierinWA
Oct 7, 2015 10:15 AM
jaridjohn
Oct 5, 2015 07:01 AM
djmarch
Oct 2, 2015 10:41 PM
meeklay812
Oct 1, 2015 03:46 PM
