MSD Coil Question
Old Mar 20, 2005 | 12:06 PM
spitcricket's Avatar
Car: '91 Camaro RS
Engine: 3.1L V6
Transmission: 700-R4
MSD Coil Question
When looking online at MSD's website I couldn't figure out all the specs on there coils.
Here's an example of the Blaster GM Coil PN8226.
Primary Resistance: 0.45 Ohms
Secondary Resistance: 5.5K Ohms
Maximum Volts: 48,000
Inductance: 7mH
Turns Ratio: 85:1
Peak Current: 220mA
Spark Durration: 250 Us
I will be using the stock distributor (at least for now), Autolite double platinum plugs, ACCEL 8.8mm spark splug wires, and ACCEL cap and rotor. I was told you need spark plug wires with low resistance in Ohms but I don't know what number is low and I couldn't find out how many Ohms of resistance my wires have.
I'm up for using any brand of ignition coil and want one that's not going to burn up with alot of street use because this is not going on a dedicated strip car. I looked at Hypertech's coil but the web page didn't give the Part number for one that would fit my 1991 Camaro V6. Thanks for all the help in advance!
Old Mar 20, 2005 | 03:15 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
i am running the msd coil on my car. i have accel 8mm wires. they seem to be fine. i have burned up a couple of rotors in the distributor though. i don't know if it was directly related to the coil or not but, stock type ones didn't last more than a few months. now, i'm running a msd cap and rotor also.
Old Mar 20, 2005 | 04:24 PM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
I the conrad cap and rotor form AZ i think they changed the name but it has brass and is there higher end cap and rotor kit never had a problem with it. Your wires should be more then fine i run 8mm MSD wires.
Old Mar 20, 2005 | 05:23 PM
Car: 91 Camaro
i went through conrad's cap and rotors too. i didn't really expect to cause i heard that it was the same stuff as msd but, it didn't work for me.
Old Mar 20, 2005 | 05:26 PM
FAST RS's Avatar
From what i heard they make MSD's caps and rotors.
Old Mar 20, 2005 | 05:28 PM
Car: 91 Camaro
i thought it was the other way around. but, either way, the two supposedly are tied together somehow.
9192camaro
16
Feb 3, 2019 12:21 AM
stalkier
Dec 6, 2015 11:25 PM
theurge
Aug 21, 2015 12:46 PM
redmaroz
Aug 16, 2015 11:40 PM
midias
Aug 15, 2015 05:07 PM
