View Poll Results: Black or Midnight Blue
Pitch Black
40.00%
Midnight Blue
60.00%
Voters: 5. You may not vote on this poll
Posi rear=new axle?
Old Apr 13, 2005 | 10:06 PM
Aggp18's Avatar
Car: 1992 Camaro RS
Engine: 3.1 V6
Transmission: Automatic
Posi rear=new axle?
hello folks, well the camaro is finally starting to take off the way I want. new FAT BF Goodrich T/A's in the back, new intake system, new exhaust, rotors, blacked out tails everything. NOW, I'm a little annoyed at the single tire mark at the track, anybody know if its just gears, or the entire axle needs to be swapped for posi? I'm anxious to get some times with my current set up, and i'm hoping the posi will help on my 60' times. also, i'm thinking of re-painting the car i need a poll
Pitch Black or Midnight Blue
Old Apr 13, 2005 | 11:33 PM
7plagues's Avatar
Car: 92 Precision Red Firebird
Engine: v6->357 vortec xe262h rpm intake
Transmission: t5-> t56
Axle/Gears: 10bolt 3.42s
all u need is a posi unit.
Old Apr 14, 2005 | 06:33 AM
KED85's Avatar
Save the money for a paint job
Use a 14" VERY STICKY & WIDE "Racing tire" and you've upgrade the ratio & starting line results.
Old Apr 14, 2005 | 07:04 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
You need a posi carrier, which is several hundred dollars. Then about 200 more for install. Which is why mines not in yet.
Keep the car the stock color. Reason I say this is it will be worth more, and any paintjob on the outside thats not re-done inside the doors, hatch, underhood looks like complete ****. This is again, several hundred more dollars.
Old Apr 15, 2005 | 01:12 PM
AdmAnt13's Avatar
Car: 1990 Pontiac Firebird
Engine: 3.1 V6 soon to be gone
Transmission: 700r4 Automatic soon to be a T56
Yeah I had the same thing. So i bought an Eaton Posi differential. They are expensive and the install is expensive too as was said earlier cuz you will need new bearings which are about $80 i think. The part number is ETN-19599-010 and costs $439.95 at Summit Racing. This differential fits cars with 3.23 and numerically higher gears (almost all V6's). Only some 1982-1983 V6's came with gears numerically lower than 3.23. I bought mine off ebay for cheaper cuz it was used. Haven't had any problems with it yet.
Old Apr 15, 2005 | 01:21 PM
KED85's Avatar
A proper set up rear axle is not a cheap cake walk.
Consider other options before committing.
Which is why I threw out a 14" wide sticky tire to be as effective as it could be for the cost involved. Lower rear axle ratio (higher numerically) and gain better starting line launch (learn starting line technique better) at same time.
Old Apr 15, 2005 | 05:05 PM
Aggp18's Avatar
Car: 1992 Camaro RS
Engine: 3.1 V6
wow i had no idea it would cost so much money for posi. perhaps i'll just invest in the 14's, i'm sure that will do enough for what i need. probably a lot cheaper too, as far as the color. i've decided to keep it stock for the authentic look, as well as the financial reason. thanks guys
Old Apr 15, 2005 | 06:08 PM
85berlinetta2.8's Avatar
Car: IROC Z
Engine: 5.7
did ANY v6's come with posi? and how would i know if a thirdgen had it in?
Old Apr 15, 2005 | 06:50 PM
7plagues's Avatar
ok i got mine for a trade. i got a slp take off and richmond gears. called a place and they quoted 325 for bearings and install kit and install. not to bad. or you could just get an entire rear off a 4th gen car and bam! posi and gears and rear brakes.
Old Apr 15, 2005 | 07:41 PM
KED85's Avatar
Our V6 have the better gears (3:42).
One need adapt "somethings" for a Fourth Gen axle assembly "AS IS" to fit our 3rd Gens.
Give a 14" tire set up a try & see if the results warrant the "cost". Ya should be able to find a 14" wheel for FREEE. Cost then is only tire! Find a super sticky drag racing type tire for best results. Mickey Thompson is one good brand.
Old Apr 15, 2005 | 10:36 PM
camaro350man's Avatar
Car: 1988 Pontiac Firebird
Engine: 2.8 Lt
Transmission: 5 Spd
I have a BFG comp T/A Drag radial and that sucker will not break loose once it is sticky. If i pop the clutch at 5000 nose lifts very high
Old Apr 15, 2005 | 10:38 PM
cooltc2004's Avatar
Car: 1992 Firebird
Engine: 3.1L V6
Transmission: 5 Speed Manual
Axle/Gears: 3.42 Peg Leg
V6 Thirdgens from 1984 - 1992 had 3.23 gears in the back.
Old Apr 15, 2005 | 10:54 PM
AdmAnt13's Avatar
I agree, not 3.42.
Old Apr 16, 2005 | 03:08 AM
KED85's Avatar
Seems majority here have the 3:42.
Maybe time for a new thread "what ratio you packing"?
Old Apr 16, 2005 | 07:28 AM
Dale's Avatar
Engine: 350 S-TPI
Earlier v6 did have 3.42's up to about 89/90'ish.
Then it switched to "do you have auto or manual".
Autos got 3.23
Manuals got 3.42
If you go to main page of this site and look at the yearly info, it shows this.
Old Apr 16, 2005 | 08:36 AM
AdmAnt13's Avatar
Autos got 3.23
Manuals got 3.42
That makes sense. I have auto with 3.23 gears.
Old Apr 16, 2005 | 05:07 PM
cooltc2004's Avatar
Car: 1992 Firebird
Engine: 3.1L V6
So wait, I have a 5-Speed. I HAVE 3.42 GEARS?
Old Apr 16, 2005 | 05:38 PM
RTFC's Avatar
Car: Agood2.8,
Engine: V6rsr,
Transmission: Afrikingoodtime
I had 3.42's on an '87 2.8. I switched them down to 3.23's becuase they are much better suited for a 700r4. Especially when the 2.8 is putting out more than stock power. Hence why the larger motor cars when to even lower gears for pulling through each gear broader. For racing, go up. But for daily driving and all around higher speed use (freeways), go lower.
Old Apr 16, 2005 | 06:51 PM
Car: IROC Z
Engine: 5.7
are gears different than a posi unit? or if i found a car that had a posi unit would it be switching gears too?
Old Apr 16, 2005 | 08:24 PM
KED85's Avatar
See any Hot Rod or Car Craft or any car magazine
but yes
A DIFFERENTIAL (in this case of discussion, posi unit) and GEARS (3:42/3:23)are two different items HOUSED in the rear axle assembly!
Old Apr 16, 2005 | 08:48 PM
Aggp18's Avatar
Car: 1992 Camaro RS
Engine: 3.1 V6
I have an auto with 3.23 gears. To be honest with you guys though, on the street my BF goodrich don't really brake loose unless I run up to about 2500 rpm half petal. Once I heat them up, I imagine they should grip even better on the track. Well, I have to run the car first at the track to even get an idea of slippage. I'm really hoping for mid to low 16's for my first run in this car. I had an oldsmobile alero which hit a 15.7 completely stock. I couldn't believe it, so i'm hoping for similiar results with this. If you look in the street racing posts i ran a 3.4 95 camaro, anybody have any ideas on times with them? We were pretty much on a dead heat until 75, so I imagine times will be similiar.
hectre13
Dec 11, 2023 08:14 AM
Reddeath210
Oct 6, 2015 08:20 AM
tcflint
Exterior Parts for Sale
Aug 26, 2015 05:45 PM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
AkDrifted
Aug 17, 2015 07:45 PM
