Valve covers and up?
Old Apr 21, 2005 | 09:02 PM
camaro350man's Avatar
Car: 1988 Pontiac Firebird
Engine: 2.8 Lt
Transmission: 5 Spd
As you know I'm in the process of putting my motor back together. I have to get it all down tomorrow because I need to go to work the following day, so hopefully this thread will get some good reponses when I put the valve covers back on do i put RTV on the gasket where it mates on the valve cover and on the part where it mates the head or just on the valve cover? And how long should it sit for? And on the lower and up plemun on gaskets do I use RTV? Thanks guys
Old Apr 21, 2005 | 09:12 PM
Engine: 2.8 Lt
Transmission: 5 Spd
Should I tighten the rcokers/lifters at all or just leave them? And how tight should they be
Old Apr 21, 2005 | 10:36 PM
67 Camaro 88's Avatar
Car: Camaro
Engine: 3800
turn and a half past zero lash
Old Apr 21, 2005 | 10:44 PM
Engine: 2.8 Lt
Transmission: 5 Spd
WHats that mean? Never did it before, sorry
Old Apr 21, 2005 | 11:01 PM
oldschool's Avatar
Car: 1985 Pontiac Firebird
Engine: 2.8 LB8 HO
Transmission: 700R4 with OD
Axle/Gears: 10 bolt 7.625 open-factory 3.42
According to the GM service manual: place a dot of RTV on the cylinder head intake manifold split line, (sort of a joint in the back of the flange of the head where it meets the intake manifold). This is the only RTV you use. Make sure the valve covers, and head flange are clean of oil and dirt. Brake clean on a rag works well here. Put the gasket over the valve cover studs, place the cover carefully on top, next the load spreaders, and the nuts. Tighten the valve cover nuts until the load spreaders are flat, and then stop. Don't over tighten. Done
Old Apr 21, 2005 | 11:10 PM
Engine: 2.8 Lt
Transmission: 5 Spd
How do you equally tighten the plenums down. Star patter? any advice on how to? Thanks
Old Apr 21, 2005 | 11:47 PM
kretos's Avatar
Car: 89 Iroc
Engine: lb9
Transmission: wc t-5
Axle/Gears: 10 bolt 3.08 posi
always do the 4 corners first, then work your way in alternating criss cross style
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
Nick McCardle
Sep 10, 2015 08:36 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
