How it could be?
Old May 10, 2005 | 02:39 AM
Petrovich's Avatar
Car: Chevy Camaro RS 1992
Engine: 3.1 L
Transmission: Automatic
How it could be?
In the previous thread
https://www.thirdgen.org/techbb2/sho...hreadid=292889
I wrote that I have found the way how to read ECM data.
After several tests I found that MAP sensor reads 200 kPa when engine is not running. How it could be? I definitely have 1 bar MAP sensor and 1227730 ECM. I suppose it is different chip possibly from turbo charged engine. Any ideas??? Does anybody have ECM direct from 3.1 V6 Camaro? I would buy it.
Old May 10, 2005 | 06:57 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The scan tool you are using is incorrect. The ECM outputs the MAP value as ADC counts (analog-to-digital convertor counts, 0-255, ADC * 0.019 will be the MAP voltage) and the scan tool converts that value to volts or KPa.
RBob.
Old May 10, 2005 | 07:16 AM
Petrovich's Avatar
Engine: 3.1 L
The other data from analog sensors (Temp, TPS) are correct...
Anyway it couldn't b be that for MAP sensor there is special or different ADC in ECM.
