A/C recharge question.
Old May 22, 2005 | 10:25 AM
ken3983's Avatar
Car: 1989 Firebird Formula 350
Axle/Gears: 9 Bolt Borg Warner 3.27 gears
My system has been converted to the R-134a setup about 2 years ago.I did it in October to get ready for the following spring and summer season.The idiot forgot to tighten down one of the connectors and it leaked out.I ordered a vacuum pump with a tee to do either R-134a or R-12.I am going to borrow a set of manifold gauges to do it from a friend.My question is, on the 3.1s,are the only two connectors for the A/C near the condenser?I see the low side service port on the condenser and it looks like the high side service port is a Schraeder valve near the same location.Is there anywhere else that it might be on the system?
Ken
Old May 22, 2005 | 11:51 AM
bru333's Avatar
Car: 1987 Camaro SC
Engine: 2.8L MPFI (rebuilt)
Transmission: 700R4 swapped to T5
Axle/Gears: 3.42 open
Low side is "usually" at or near the accumulator/dryer, and high side is "usually" at or near the compressor.
If you had it converted it should have the R134a adapters on the fittings. Just follow the hoses from the compressor to find them. Should have a blue cap on the low fitting and a red cap on the high fitting.
jrdturbo
Mar 31, 2016 02:58 PM
2012sergen11
Oct 13, 2015 07:38 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
Ironhead38
Sep 7, 2015 02:26 PM
Ian Irvine
Sep 4, 2015 08:08 AM
