smog delete pulley
Old May 22, 2005 | 09:42 PM
Rebel 92 F-bird's Avatar
Car: 92 F-bird, 1965 Goat (GTO for those who don't know what a Goat is.)
Engine: 3.1 V6, 400 w/3 2 bbl's
Transmission: 700-R4, TH350
smog delete pulley
Where can I get a smog pump delete pulley? none of the local junkyards have any cars that have one.
Old May 23, 2005 | 07:06 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
shouldnt need one. just get a belt for your car w/o the smog pump. not sure what part numbers are, but i think i remember seeing it. try a search
Old May 23, 2005 | 08:34 AM
Nocturnall's Avatar
Car: 91 Firebird
Engine: 191ci 6cyl
He might not be able to, I can't just get a belt to skip the smog pump on my car because it goes from the smog pump to the water pump, not the crank.
Old May 23, 2005 | 08:37 AM
drdave88's Avatar
Engine: 6.0L
i didnt realize there were differences in routings between the 2.8 and 3.1
Old May 23, 2005 | 08:59 AM
Nocturnall's Avatar
Car: 91 Firebird
Engine: 191ci 6cyl
could just be my car, but it goes around the alt, around the smog pump, to the water, then the crank and around. I just took my smog pump off, cut out everything from inside of it and put it back on, it's only like 2 fins you need cut out. Still causes a drain on the system but it doesn't make the annoying scraping sound anymore.
Old May 23, 2005 | 09:51 AM
mieta's Avatar
Car: Camaro 1990
Engine: 3.1 v6
just reroute your serpentine belt, thats what i did.
Old May 23, 2005 | 10:14 AM
RTFC's Avatar
Car: Agood2.8,
Engine: V6rsr,
Transmission: Afrikingoodtime
Here,route it like this. This is the factory "delete" of the smog pump. They removed it entirely on the '87's because they were burning efficiant enough not to have to have them. The factory just put on a smaller belt and routed them like so
Old May 23, 2005 | 10:53 AM
LT1guy's Avatar
Car: 1987 Trans Am
Some 3.1s had an idler pulley in the general location of where the smog pump would be. Its by no means necessary, but on Redraif's car we had a fair amount of movement/whipping in the belt without it (her car didn't come with a smog pump, since its an 87), so we added one.
Old May 23, 2005 | 11:24 AM
redraif's Avatar
Car: 87 Red/Blk Bird loaded 3.4L & 700R4
Transmission: Th700R4
Also had a hard time getting the right size belts at the parts stores for the smog delete option! Usually had to get one and it would fit for a bit and stretch just slightly and start squealing and flapping!
Old May 23, 2005 | 02:18 PM
Nocturnall's Avatar
Car: 91 Firebird
Engine: 191ci 6cyl
great, probably gonna be all kinds of fun trying to get one to delete my smog pump and fit with an crank underdrive pully.
Old May 23, 2005 | 02:51 PM
drdave88's Avatar
Engine: 6.0L
heres what i did for the delete and an underdrive pulley. it still took a bit of trial and error but. took a piece of rope, ran it around the routing of the belt, measured it and subtracted about an inch and a half for the tensioner. ill check the belt part number when i get home, but i think it was around 73 inches
Old May 23, 2005 | 03:11 PM
redraif's Avatar
Well I was running the underdrive pulleys w/o the pulley and that was part of why I had so many belt issues!
We had to do the same thing to get a decent belt...rope trick is the best way! Everything runs so much better with the idle pulley though!
Old May 23, 2005 | 05:19 PM
Nocturnall's Avatar
Car: 91 Firebird
Engine: 191ci 6cyl
I got an idle pully, when I replaced the belt for the underdrive pully it came down to trying them on in the parking lot of the parts store.
Old May 23, 2005 | 05:31 PM
redraif's Avatar
Old May 25, 2005 | 09:46 PM
DustyJL's Avatar
Car: 91 Camaro RS
Engine: 3.1L V6
Axle/Gears: Stock 3.23 open diff
Would I be able to go to the auto store and ask for a belt for a 87 camaro w/o a smog pump and get the right size for my 3.1L??
Old May 26, 2005 | 09:00 AM
KED85's Avatar
See the replys above!
I see no big deal except hearing that noise.
The HP loss is if any so small.
PS Those internal fins looked pretty easy to remove from the smog pump housing.
Old May 26, 2005 | 11:56 AM
redraif's Avatar
You might get lucky, but chances are you will have to play around with belts a bit the first time then just write the correct size in you service manual for future reference...thats what i did!
Old May 27, 2005 | 05:08 AM
Nocturnall's Avatar
Car: 91 Firebird
Engine: 191ci 6cyl
Ked you can't just take those fins out, I had to cut them in half with a dremel to get it out.
jaridjohn
Oct 5, 2015 07:01 AM
