Anyone know what this sensor/switch is?
Old Jun 1, 2005 | 01:14 AM
Highwind's Avatar
Car: 1988 Firebird
Engine: 305 TBI
The 3.1L is from a 91 Firebird. This has a single green wire connector that is at front left corner of the driverside head. I've read on the forum and in my haynes manual (diagram for an 87 2.8L) that the radiator fan switch is located at the rear of the passenger side head but I've searched to no avail. I saw another post where someone else with a 3.1 could not find it either. The connector in the pic doesn't look like a fan switch connector but I'm still curious as to what this sensor/switch can be. Thanks in advance.
Old Jun 1, 2005 | 06:57 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
coolant temp sensor
Old Jun 1, 2005 | 07:22 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Anyone know what this sensor/switch is?
That sensor is the coolant temperature for the dash gauge (single green wire). On the front/top drivers side of the intake manifold is the coolant temperature sensor for the ECM (2 wires). The fan on the 3.1 is ECM controlled, with additional control via the A/C high pressure switch. No fan switch in pass head on the 3.1's.
RBob.
Old Jun 1, 2005 | 01:40 PM
KED85's Avatar
IS THIS
Same thing &
Same location for
1985?
THANK YOU
Old Jun 1, 2005 | 02:50 PM
bru333's Avatar
Car: 1987 Camaro SC
Engine: 2.8L MPFI (rebuilt)
Transmission: 700R4 swapped to T5
Axle/Gears: 3.42 open
Originally posted by KED85
IS THIS
Same thing &
Same location for
1985?
THANK YOU
Should be. My '87 is the same.
