TPI replacement
Old Jun 13, 2005 | 03:06 AM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
TPI replacement
replacing my TPI. should i go with a new stock unit or is there some sort of aftermarket better one i can get?
Old Jun 13, 2005 | 10:53 AM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
what exactly are you replacing? TPI refers to the whole intake setup. also, TPI is what the V8s have...we have MPFI. same basic thing just technically a different setup. anyways, you replacing the manifold, injectors, or what?
Old Jun 14, 2005 | 01:31 PM
Xophertony's Avatar
Axle/Gears: n/a
arghh!!!!
I MEAN TPS!!!
i keep doing that... don't reply here i am going to start a new thred
somone delete this
Old Jun 14, 2005 | 05:02 PM
KED85's Avatar
Check out my thread on the Throttle position sensor cost & let that be a guide.
Vintageracer
Jan 10, 2020 05:33 PM
gta90
Sep 15, 2015 04:00 PM
NBrehm
Aug 25, 2015 11:49 PM
Sanjay
Aug 12, 2015 03:41 PM
marcusaw
Aug 10, 2015 08:13 AM
