part of my exhast rattling......
Old Jul 29, 2005 | 12:00 AM
Firebreed's Avatar
Car: 2011 SS/RS
Engine: LS3
Transmission: Tremic6060
Axle/Gears: good enough
Alright... The part of my exhast system that is rattleing is right at the cat, it only happens at idle (sounds like a engine knock from the interior, but is NOT an engine knock, it is not comeing for the engine bay) could this be a loose hanger? or could it be the cat it self? if its the cat then how was i able to pass smog with flying colors? The only time the rattle/knock what ever you want to call it is when is jarred (ie: tapping on the pipe with the side of a flash light) I did bottum on on a speed bump once, but i wasnt going more then 3 or 4 mph (i take i slow on speed bumps) i would put this on the exhast forum, but i like to get fellow v6 owners oppions first. Could it be somthing else? (keep in mind it is not an engine knock)
Brandon
Old Jul 29, 2005 | 12:06 AM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
Be careful of when the tech tells you that it passed with "flying colors". Unless your numbers are all right about average, then it's not flying colors. Just don't want you to be one of those people who get their hopes up and have it fail in 2 years, then be telling the tech, "but it passed 2 years ago! What the hell?"
It could be the cat. they rattle when they break loose in the housing. So if you bang on the cat itself, it rattles, right? Just trying to get clarification. Even with a cat that rattles, it might not have turned sideways yet and it'll still work as long as exhaust gas is flowing through it and it's not contaminated.
Something else you might want to check out is the heat shield right above it. It's a two-peice sheild made of aluminum, and it's rivited together, mine made this wierd rattling sound at idle too, then I rivited it back together and the problem was solved.
Old Jul 29, 2005 | 12:28 AM
Firebreed's Avatar
Car: 2011 SS/RS
Engine: LS3
here are the numbers, all were about average or a little above , except for the NO, The rattle happens when either i tap on the cat or the pipe that is leading to the y-pipe(if thats the right term) to the manfolds, when i tap on the pipe i tap right by the cat. Ill check the heat sheild tomaro, i got a few rivits in the tool box and if that doesnt do the trick then i think im start looking for a new cat/mufflar system (since they are 22+ years old, and doesnt look like they have been replaced) dont know if the numbers will help but the car performed better at smog then i though so
And the numbers
For the HC
at 15mph, Max was 135 Mine 23 avg 45
at 25mph Max is 108 mine 21 avg 33
For CO
at 15 mph Max was .97 mine .16 avg .16
at 25 mph Max was .77 mine was .24 avg .14
For NO
at 15 mph Max was 1125 mine was 0654 (a bit high but for the age of the car not bad qoted from the tech) avg 434
at 25 mph Max is 955 mine was 0667 (still, a bit high but for the age not bad quoted from the tech) avg 357
Old Jul 29, 2005 | 07:50 AM
Car: 1988 Camaro RS
Axle/Gears: 3.42's
Yeah, your numbers are suprisingly good for the age of the cat if it is infact the original. Does your cat look like it has a kind of wire mesh around it or does it have an all aluminum shell?
Old Jul 29, 2005 | 09:50 AM
KED85's Avatar
UNtil you get great visual access at the Cat Convertor area, kinda hard to tell what's going on.
Great going that you passed your tests.
That's one aged engine you are working with.
Please not a put down. I had "that engine" in my 1985 Blazer for 211,500 miles until it died.
It could be a strap that hooks exhaust to tranny, too.
Old Jul 29, 2005 | 12:22 PM
Firebreed's Avatar
Car: 2011 SS/RS
Engine: LS3
it doesnt have a wire mesh around the cat, but on the bottom side (the side faceing the road) it looks almost like a wire mesh, the rest of it could be either steel or aluminum i cant tell cause its preaty much all surface rust covering it. if you all need a pic i can go get one.. just got to find some batteries to use
Old Jul 29, 2005 | 12:36 PM
Dan8289gta's Avatar
Car: 89 GTA
Engine: 350 tpi
Mine was rattling, it was the heatshield on top of the cat. I pulled it off with my bare hand and solved the problem
Old Jul 29, 2005 | 03:22 PM
Car: 1988 Camaro RS
Axle/Gears: 3.42's
Yeah, I've seen that done, but the passenger doesn't need to wear socks in the winter then.
It's about a foot long, maybe a foot and a half, then yes, that is the factory cat. EWWWW!!!! Probably dead seeing as that it's been in there forever!
Old Jul 29, 2005 | 06:11 PM
Firebreed's Avatar
Car: 2011 SS/RS
Engine: LS3
Yea its the stock cat, could the cat be dead even though the car only as around 75000 miles on it?
Old Jul 29, 2005 | 08:34 PM
KED85's Avatar
In your case it's not miles it's previous owners & the years of usage!
I'd plan on changing it
Old Jul 29, 2005 | 11:21 PM
Firebreed's Avatar
Car: 2011 SS/RS
Engine: LS3
what would be the best type of cat to replace it with? a free flowing one? keep in mind im on a college kids budget, cant spend 100's of dollars on a cat.
Old Jul 30, 2005 | 12:54 AM
Car: 1988 Camaro RS
Axle/Gears: 3.42's
Magnaflow is a good choice. I think that's what Karl put on his 'bird.
Old Jul 30, 2005 | 07:21 AM
KED85's Avatar
Yep
Magnoflow!
23494
Used for a 3.4 1995 & it fit perfect my 1985 Firebird set up.
IF I WAS YOU
My first hop up on my 1985 Blazer was a decent Universal CC
I used a 2 1/2" in & out, had the pipes modified by welder for the CC install.
I know I gained some free flow power.
Every little bit helped.
My CC cost me (for the Firebird the Magnoflow) $113 including shipping.
Old Aug 3, 2005 | 09:58 PM
Firebreed's Avatar
Car: 2011 SS/RS
Engine: LS3
2.8 boy.. would this cat be cal legal?(or anybody else that is CAL smog knolegeable)
this cat
Old Aug 3, 2005 | 11:29 PM
Car: 1988 Camaro RS
Axle/Gears: 3.42's
Any cat is good enough on an OBD-I car (pre-1996)
As long as it's on there, you're good to go.
Old Aug 3, 2005 | 11:32 PM
Firebreed's Avatar
Car: 2011 SS/RS
Engine: LS3
thanks! what size pipes should i be looking at?
Old Aug 4, 2005 | 09:02 AM
Car: 1988 Camaro RS
Axle/Gears: 3.42's
I'm pretty sure that stock is 2 1/4 inch, but if you want to do a small upgrade while you're at it, you can have the rest replaced with 2 1/2" piping, I think that's the general consensus on a good size pipe for the 6's
Old Aug 4, 2005 | 09:15 AM
KED85's Avatar
Summit & Jeg's is source for the Magnoflow CC.
LT1Formula
20
Nov 14, 2015 12:02 AM
Thomas
Oct 3, 2015 05:34 PM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
1nastygta
Aug 8, 2015 07:38 PM
