mechanical oil gauge.
Old Jul 31, 2005 | 06:14 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
Where do I connect one on a 2.8 V6 I know on the 305 there is a nut behind the distributor. I was wondering if there was an equivilant
Old Jul 31, 2005 | 10:27 PM
85SportCoupeto89RS's Avatar
Car: 85 Camaro SC
Engine: V6
Simply, the best place to put the mechanical gauge's oil line on the engine is to use the hole that either your oil sending unit or oil switch uses. Since you have a Berlinetta i'm not to sure which kind it use's but it is located right next to your oil filter, though I can not remember what size the taper threaded hole is at the moment.
Hotrodboba400
Dec 10, 2019 07:07 PM
Jk_Under
Sep 8, 2015 08:13 AM
tgp1990
Sep 4, 2015 06:24 AM
jtwoods4
Sep 3, 2015 05:39 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
