Oxygen Sensor and TCC
Old Aug 22, 2005 | 10:40 PM
JP8528V6's Avatar
Car: 1985 Firebird
Engine: 2.8 V-6
Transmission: TH-700R4
Hey everyone...been sometime since i've posted last...I still have my 'Bird but not alot of time to drive it or enjoy sitting at home on the computer...I got a couple questions...First my computer threw a code for the o2 sensor...My cat was really clogged up and i thought maybe that was causing the sensor malfunction...I had the cat replaced and then I went ahead and changed out the o2 sensor...It was about 3 or 4 years old...30,000 miles on it...So I changed it and i'm still getting a code 13...the sensor is leaning out on warm engine cruise...this will happen after driving for about 10 minutes...sometimes it comes on and off...other time it stays on...or doesn't come on at all...anything else that could be throwing this off...i read in my service manual possibly the TPS is sending false info...And I did have problems with the TPS about a month ago...the voltage was wrong and everytime I put the car in drive and went to accelerate the car stalled out...I set the voltage to where it should be according to the book...just wondering if anyone knows what could be causing that code since the o2 is new...second is can i manually wire my tcc to lock up when i want...it locks up too early and then the car has a tendency to buck...is there a way i could put an interuptor switch in between and just kick it on after 40mph or so...I'm sure i'll get some good advice as this forum has been the most helpful i've encountered on the web...thanx guyz...
Old Aug 24, 2005 | 10:40 AM
JP8528V6's Avatar
Car: 1985 Firebird
Engine: 2.8 V-6
no takers yet...
Old Aug 24, 2005 | 02:14 PM
bru333's Avatar
Car: 1987 Camaro SC
Engine: 2.8L MPFI (rebuilt)
Transmission: 700R4 swapped to T5
Axle/Gears: 3.42 open
Re: Oxygen Sensor and TCC
An intermittant code could be a problem wth the wire. Check the wire for breaks or bare spots, and the connection at the sensor for dirt or corrosion.
Old Aug 24, 2005 | 02:58 PM
JP8528V6's Avatar
Car: 1985 Firebird
Engine: 2.8 V-6
yea...i'm the connector checked out...but i'll have to follow the wire along to see if there are any breaks or barespots that might be grounding out or such...i'll post back in the next day or so cause the car isn't here right now...i decided to switch rides until i figure this out...thanx for the info...
HoosierinWA
Oct 7, 2015 10:15 AM
aaron7
Sep 30, 2015 09:15 AM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
dusterbd
Sep 29, 2015 08:40 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
