need help can drive past 3000 RPM
Old Oct 10, 2005 | 01:56 PM
Teenfixing88RS's Avatar
Car: 1988 Camaro RS
hello
this problem arose a few weeks ago but now im too scared to drive my car (daily driver)
any gear i put it in i cant go past 3000 rpm.
as soon as i hit that mark the car jerks rpms go crazy and car dies (at times)
ive check transmission fluid and engine oil both are good.
any idead wat maybe causing this?
V6 2.8l manual transmission
Old Oct 10, 2005 | 02:56 PM
Dizturbed One's Avatar
Car: 92 RS
Engine: a slow one
Transmission: a crunchy one
Axle/Gears: a whiny one
ignition system
if it happens dead on a certain RPM every time, I'm pretty sure it would have to be ignition.
I'd start with the basic tune up items, then move on to bigger things.
Cap, rotor, wires, plugs <--- do that first.
Old Oct 10, 2005 | 04:12 PM
Ziggster's Avatar
Car: 1988 Camaro
Engine: 173 CI
Axle/Gears: open 3.42's
might check the cat to if you have one still that can sometimes limit RPMS when they get plugged
Old Oct 10, 2005 | 04:58 PM
Car: 1988 Camaro RS
i will replace the plugs soon. the thing is i just had a tune up not too long ago but it maybe time for a new one.
and as for the cat being a prob. i just had the pace setter header installed with the dyno max exhaust. so its new everything.
the problem started b4 i had all that installed
thanks for the help guys
Old Oct 11, 2005 | 01:50 AM
83Blackwidowz28's Avatar
Car: '91 Rs
Engine: 3.1 MPFI V6
Transmission: 700R4 B&M Shift Kit 2300-2500 stall 9" tq
Axle/Gears: stock 10bolt 3.23 gears
Hey i had the same prob with my 89 iroc every gear it would die and would not move. had to feather the throttle to keep her alive. Checked everything out and found out it was the fuel pump and ignition module. I dumped the converter thought it was plugged still died, check the TPS, IAC and MAP sensors all good. But it def. sounds like my problem and it was the pump
Old Oct 12, 2005 | 12:05 AM
Car: 1988 Camaro RS
ok
my car died last night no power what so ever. no start.
i tried switching the battery and nothing.
ill check the things Blackwidowz28 and keep it updated
thanks
Old Oct 23, 2005 | 05:51 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
ICM and Pickup are the things that I would start with. You can get a hold of a rebuilt distributor that comes ready to stab for like $120 at autozone. It already comes with a new ICM installed too.
It does it just simply die or does it start to misfire at 3K?
specialized
Jun 18, 2022 09:26 AM
gta90
Sep 15, 2015 04:00 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
