Help! Look up
Old Jan 25, 2006 | 08:10 AM
inisross's Avatar
Help! Look up
My husband has pulled a hydraulic clutch from a 1985 camaro 2.8L with a T5 to put into our 1988. We do not have a manual for a 1985, would someone please lookup for us the torque for the pressure plate to flywheel bolts. They are 8mm bolts.
Thank you in advance.
Old Jan 25, 2006 | 01:56 PM
inisross's Avatar
Thank you to everyone who tried to help, I did find the information I needed on another website.
The information for future reference is:
Pressure plate bolt should be a 5/16 and torqued to 20#'s.
My husband had already retapped and purchased the 5/16, so it is working out nicely.
If the bolts had been the 3/8's that a lot of the GM's call for the torque should be 25#'s.
Again thank you for your time and efforts.
Old Jan 25, 2006 | 02:59 PM
Naft's Avatar
Car: 89 Firebird, 92 RS
Engine: 2.8L MPFI, 355 TPI
Transmission: t-5, t-5
Axle/Gears: open 3.42, posi 3.42
Thanks for posting the info, now if someone searches it will be here.
