msd fuel pump
Old Feb 14, 2006 | 09:07 AM
williet's Avatar
msd fuel pump
my in tank fuel pump is bad on my 1990 pontiac firebird 3.1 v6. i was wondering if i could use a out of tank msd universal fuel pump. my fuel pressure is 34 to 47 psi and the msd has a max of 86 psi. could i do this? if yes what would be a good source of power controlled by the ignition system.
will
Old Feb 14, 2006 | 09:59 AM
Drew's Avatar
Unless you pull the stock pump out and rig a pickup you're going to be pulling fuel through the stock pump... not exactly an ideal situation.
If you've got to pull the tank to change the pickup you might as well install a new factory style pump and not have to mess with again for another 10+ years.
Old Feb 14, 2006 | 10:07 AM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Though you want the lt1 pump me thinks or someone will correct me. But stock v6 pump has plastic parts, there is a better one with metal parts/ gears, what not.
Key to long in-take pump life is not running low on gas all the time. Reason the pump is in the tank is to well keep it cool. The gas stop its from overheating. Best to pretend around half a tank is empty.
Every once in a while I like to run some MMO in the gas to lub the pump some and the rest of the FI system too.
Old Feb 14, 2006 | 11:56 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
the metal gears inside one is a true acdelco pump for a 1989 vette.
Old Feb 14, 2006 | 05:27 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Did some price checkin
metal gear pump $140-$180
Stocker $62 no strainer
Stocker kit Ebay, with strainer $49 shipped
Item number: 8036531790
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
9192camaro
16
Feb 3, 2019 12:21 AM
theurge
Aug 21, 2015 12:46 PM
92camaroJoe
Aug 13, 2015 06:07 AM
