Anybody know what these two "Sensors" are
Old Mar 3, 2006 | 12:26 AM
Firebreed's Avatar
Car: 2011 SS/RS
Engine: LS3
Transmission: Tremic6060
Axle/Gears: good enough
the car is a 83 berly, 2.8l CARBED three speed auto
the "sensors" for a lack of a better term are located on the right side of the power break booster (from the front of the car, looking at the engine) here is a photo of the two sensors one looks to be a MAP sensor, but im at a loss over what the other one is.
Old Mar 3, 2006 | 01:54 AM
TraviZ's Avatar
Car: '02 Z06
Engine: L33 5.7
Axle/Gears: Stock IRS
the right one is for map, and the left one is a relay. could be maf burnoff, fuel pump, headlights.
not sure with the v6 models.
unplug it and find out what doesnt work.
Old Mar 3, 2006 | 01:56 AM
Firebreed's Avatar
Car: 2011 SS/RS
Engine: LS3
Thanks TraviZ
I'll do that tomarow..
Old Mar 3, 2006 | 04:02 AM
Xophertony's Avatar
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
EDIT* discovered upon reading what i wrote and seeing the pic i linked that i was wrong... so verry wrong.
Old May 19, 2008 | 05:19 PM
ramshead's Avatar
Re: Anybody know what these two "Sensors" are
ithink you will find that inside there is a fuse for your fuel pump @ oil pump .gm used them about that time to shut them off in case of a rollover.just pop the cap up and look inside should see a 25 amp blade type fuse. car will not start if fuse is blown.
