Crate 3.4-2.8 swap
Old Apr 19, 2006 | 12:13 AM
david86camaro's Avatar
Car: 1986 Camaro
Engine: 2.8
Crate 3.4-2.8 swap
I have a quick question in the past I have seen a crate 3.4 engine designed to replace 2.8 carberated engines in S-10's. I was just wondering if it would be posible to use one of those crate engines to replace a multi-port fuel injection engine. I would asume that it isn't posible or I would have been able to find something about it here, I tried to search for it. Thanks for any input.
David
Old Apr 19, 2006 | 05:52 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
I can be done, its basically the same thing as a camaro 3.4. However, that cam that it comes with is designed for carb use, and will not respond well to the mpfi intake/ecm.
Old Apr 19, 2006 | 02:16 PM
Car: 1986 Camaro
Engine: 2.8
So if I did it I should replace the cam, Thanks
Another question is would it be worth it or just as good and cheaper(?) to pick up a rebuilt 3.4.
Old Apr 19, 2006 | 03:04 PM
Dale's Avatar
Engine: 350 S-TPI
not sure on the cost of rebuilt ones. As well that may very by state/area.
Old Apr 19, 2006 | 07:07 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
are you sure on that, as the crate cam & the f-bod cam are allmost identical in specs
Old Apr 19, 2006 | 09:20 PM
Dale's Avatar
Engine: 350 S-TPI
The crate cam I read about had some massive lift, and the duration/angles were more carb designed.
Vintageracer
Jan 10, 2020 05:33 PM
theshackle
Mar 5, 2017 06:37 PM
Steve78LT
Feb 24, 2016 12:15 AM
masonta
Aug 31, 2015 10:14 PM
ezobens
Aug 19, 2015 10:29 PM
