3.1/700r4 trany question
Old Apr 26, 2006 | 07:31 PM
ron91rs's Avatar
Car: 91 rs
Engine: 3.1 v6
On my 91 rs (3.1 700r4) my rear trans pan bolts are hidden by the cross member.
My question is, is there enough play to just unbolt the single trans-to cross-member bolt and jack trany up so I can slide cross-member back an inch or so.??
Or am i going to have to remove motor-mount bolts also?
Old Apr 26, 2006 | 07:37 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
there's easily enough room.
Old Apr 26, 2006 | 09:35 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
I was barely able to remove my pan (when I had a 700r4) w/o even touching the cross member. so you should beable to move it enough by loosening the mount.
MustangBeater20
Oct 29, 2022 09:20 PM
fasteddi
Sep 10, 2015 09:32 AM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
