I have 89 2.8l camaro. I have a manual trans. and when i try to down shift from 4th to 3rd it wont let me go straight into 3rd, i have to like put it a little into 2nd and then it will let me put it into 3rd. Any1 have any ideas of what the problem is? thanx
sounds liek u may have some b ad synchros.next time u try down shifting right before u try moving the shifter into 3rd gear,tap the gas pedal to rev the engine up a bit, and see if that helps
I tried it and it did not work thanx anyways i tried shifting through the gears while the car was off and even then when i try and go from 4th to 3rd it won't let me
maybe the dog ears on the collar are messed up really badly from someone mis-shifting all the time.
