Cluster swap question
Old May 20, 2006 | 09:06 PM
87LG4FORMULA's Avatar
Car: 87 Formula/ 87 IROC-Z
Engine: LT1/L98
Transmission: modded700R4s
Axle/Gears: 3:23 posi/?posi
V6 Camaro Question: With the new cluster in everything works except the tach but the SES light comes on and codes the VSS. This was not the case with the new engine (2.8 '87Firebird with all senders for the guages) and the old cluster so a buddy suggested I substitute the old speedo in the new cluster. He wasn't sure tho. Anybody know if this will work. Also can the tach be made to work? The donor for the cluster was a Zed so a V8, likely an LG4 (carb, no VSS) but I did not get the year (swap meet special $30). Any help or referral would be cool!
I still have the original cluster of course but with the swap the idiot lights didn't work right.
Old May 20, 2006 | 09:58 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
did you have to rewire teh cluster harness in the back? I had to on teh bird when I swapped in a vss cluster due to the swap.
Old May 20, 2006 | 10:40 PM
Engine: LT1/L98
Didn't do a thing to the cluster, yet...
Old May 21, 2006 | 11:38 AM
bru333's Avatar
Car: 1987 Camaro SC
Engine: 2.8L MPFI (rebuilt)
Transmission: 700R4 swapped to T5
Axle/Gears: 3.42 open
No need to swap pins on a Camaro for a different gauge cluster. The printed circuit film on the back of the clusters is different for the idiot light cluster and the gauges cluster, harness connector pinouts are the same. I speak from experiance as I swapped from the idiot lights to a gauges cluster in my '87.
The tach runs off a signal from the distributor, and 12Volt from the battery. 12 volt on the pink/black wire, and white wire. If you have power and ground (black wire) to the tach then that tach is bad (or the printed circuit on the back of the cluster is damaged).
Old May 21, 2006 | 06:18 PM
Engine: LT1/L98
Searching found the same problem as another guy who put in a v8 tach. The oil pressure goes off the chart, but my tach doesn't move. The advice to him was to get a v6 tach/oil pressure guage (They are together) Hopefully I can find one of those in the wreckers easily enough. Still not sure about swapping the speedo, is the VSS in the cluster somewhere, cuz it did not pull a code with the stock cluster.
Frozer!!!
Jan 19, 2024 04:55 PM
Jeremys87
Jul 14, 2022 09:08 PM
355sbcTPI
Aug 19, 2015 04:38 PM
redmaroz
Aug 16, 2015 11:40 PM
ChevyZ71
Aug 13, 2015 07:30 AM
