Where would be a good place to get replacement vacum lines and connectors for an 89 Firebird 2.8L car? Mine are old and some are taped off
. You can imagine the issues I'm having...
Brandon
. You can imagine the issues I'm having...Brandon
I'm pretty sure most of the molded plastic lines are discontinued, but autozone sells them in three foot lengths. You can make the appropriote bends with a heat gun or hair dryer. Regular rubber lines can usually be bought by the foot at local auto shops. I certainly would not rule out the junkyard, you will typically find the connections for the lines you need in fairly good condition. They are pocket items as well
