Extreme Bogging
Car: 85 camaro sport coupe
Engine: 2.8 MFI
Transmission: v6 700R4 wish it was a 5spd Stick
Axle/Gears: Stock non posi 3.42s
Extreme Bogging
my car is doing something funny. it is Bogging till it gets to about 3000rpm then it takesoff with enough umpf to kinda halfway chirp the tires(its not a chirp but you can feel the momentary spin of the tire). I checked the codes with a shop scanner and it came across with code 42. which is somehting Electronic Timing. i cant remember EXactly what it said only that it had an error and was not working properly.
Its weird in the fact that it only boggs to about 3000 and it only does it like once in every 100 starts. Its kinda scary when i take off behind some one and it boggs then with out warning it goes like a bat outa hell. I have come with in inches of rearending people that way. it boggs so bad that you have to use wot gust to get the car rolling then it decides to run like or better than normal and your heading towards the car infront of you at WOT.
RedLeader289
May 28, 2019 01:47 PM
