AC bracket modification
Car: 2012 Nissan Leaf
Engine: 80-kW AC synchronous electric motor
Transmission: Automatic
Axle/Gears: n/a
my 1986 firebird is a factory no ac car. the car was built with no AC. in all my years of scrounging junkyards i have never seen a car without an AC bracket. even my no-ac car has this ugly intrusive bracket. now, my car was not exactly original when i got it and i had atfirst assumed that somone lost the bracket while working on the engine (it was rebuilt before i got it) and replaced it with the AC one, however i have since come to believe that ALL cars recieved the smae bracket for the powersteeringpump and AC (all 2.8s that is)
so while tearing apart my engine for a valve readjustment i decided to pull the bracket off and modify it to be a bit more low profile. i am thinking of yanking it off again and hitting it with some black paint. all in all i think it cut off about 1/2 of a pound, but it was just a guess, i did not do it for weightloss, i did it for ease of maintinence in the future and engine bay beutification. anyway, here are some before and after shots.
BEFORE:
here you can see the bracket in it's stock form and location
AFTER:
a wide shot of the modified bracket.
CLOSEUP:
a close shot of the bracket
BEFORE:
AFTER:
CLOSEUP:
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
IIRC, What they did from the factory for ac delete, was put a plastic idle pully in place of the pump. The pully was same dia as the ac pully. You can find these on ebay all the time for 65'ish bucks.
Axle/Gears: n/a
yeah..... for all serpantine cars. pre-87 has vbelt still. the "v" belt goes crank, waterpump, PS, AC. and the other belt goes crank, waterpump, AIR pump, alternator. on my 86 the second belt is a serp-style belt.
my pre-87 car FROM THE FACTORY had NOTHING on that bracket. no idler pully at all. unless i am mistaken.
