Fuel Pump?
Old Aug 19, 2006 | 09:46 PM
jedibooney's Avatar
Fuel Pump?
Greetings all,
Here's my problem(s). I've been having some trouble with start-up (seems to be harder to start than normal). It acts as though the battery/starter are weak when I first try to start it. After the first start though, it seems fine. The starter was just replaced, and the alternator/battery check out (had them tested at AZ). Now, it misses at idle speed, and through slow acceleration. It is throwing a code 54 (low voltage at FP). Is my fuel pump bad? How can I be sure. I'm only a glorified tinkerer when it comes to working on a car so I'd rather not waste my time and money on fixing something that aint broke. Thanks for the help.
Old Aug 20, 2006 | 08:35 AM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
spend teh $35 to get a fp gauge , or borrow someones, & read the "key on on engine off" & "key on engien on" numbers. You should have, iirc, ~42psi w/engien off, and ~5-7 engien on readings.
Old Aug 20, 2006 | 11:10 AM
jedibooney's Avatar
I'm going see if I can borrow a gauge to test the fuel pressure. In the meantime, could a weak pump cause the "low voltage at fuel pump" error code, or should I also check the relay?
Old Aug 20, 2006 | 11:40 AM
Engine: 5.7 / 7.4
yes, should be able to use a test light to check the voltage coming out of the relay
Old Aug 21, 2006 | 11:31 AM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
Test lights only tell you that there is a presense of voltage, not how much voltage there is. Use a Digital Multi-meter to see exactly what is getting to the fuel pump and then make sure that you have a very low-resistance ground circuit.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
