3.4 ecm question
Old Oct 20, 2006 | 11:04 AM
grimmcs's Avatar
Car: 91 Camaro
Engine: 3.1/3100 in progress...Turbo Soon
3.4 ecm question
Quick question. If I swap in the 3.4, can I also swap in the ecm to use the DIS? Will it work with my 91 gauges, etc.? Thanks
Oh and yes I searched but all I found was info on using the 2.8/3.1 intake with the distributer.
Old Oct 20, 2006 | 12:17 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
if you want to swap the wiring harness too...
Old Oct 20, 2006 | 12:26 PM
grimmcs's Avatar
Car: 91 Camaro
I was tossing around the idea. But I just found that its doable but there would be a problem with my VATS system. Any other problems I missed?
Old Oct 20, 2006 | 04:31 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
vats might not be an issue, being that your car already has it & my 94 also has it. Dash wiring should be cut & splice in to your guages.
Old Oct 21, 2006 | 05:44 AM
Derickab's Avatar
Car: 1987 Camaro
Engine: 3.4 Liter
Transmission: 5 speed
Axle/Gears: stock
I was wondering the same thing. I just picked up my 3.4 yesterday, it was a sweet deal. The guy gave me the wiring harness and the ECM too, all for 150. I was telling him what I was planning on doing and he said just change the plugs at the firewall. He did the 3.8 swap in his 93 and it looks good. Now there he had to do all his wiring but said the 3.4 & 2.8 from he firewall to the intrenal harness its the same. I'm not too sure about that.
ezobens
Aug 19, 2015 10:29 PM
355tpipickup
Aug 19, 2015 10:02 PM
redmaroz
Aug 16, 2015 11:40 PM
djmarch
Aug 10, 2015 08:42 AM
