T5 In a Junkyard? T5 V8 in a V6?
Old Nov 13, 2006 | 12:46 PM
nks06's Avatar
Car: 1987 Chevrolet Camaro
Engine: 2.8L LB8
Would it be reasonable to think that if I find a 2.8 in a junk yard, and its a manual, that there is a T5 in there? If i was able to figure out that it was a T5, would it be a pretty good to get all the bolts and such from that instead of ordering them from somewhere? Also, is it possible to retrofit a V8 T5 to a V6?
Old Nov 13, 2006 | 02:30 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
2.8/3.1 5sp in a f-body will be a t5. Now depending on the year it will be a WC or NWC. You want the WC.
To get a v8 one to work, you will need to find a special clutch because the splines are different. I also belive between the v6 n v8, the gear ratios are different, but check into that yourself.
Old Nov 13, 2006 | 06:05 PM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
theres something in one of the tech articles or tech info or something like that about what trans has what gearing. i do remember that the v6 T5 has some of the better gearing, but i dont remember what exactly they have.
Old Nov 13, 2006 | 10:20 PM
daves12secV6's Avatar
i heard somethign about using a 4thgen 3.8 v6 clutch if u want to put a v8 t5 in a v6 car( supposedly it fits in the v6 bellhousing and has the correct spline count for the v8 trans)
though im not sure how much truth there is to that,though some quick reasearch could tell that
armybyrd
Sep 28, 2023 12:16 AM
okfoz
Convertibles
83
Oct 29, 2018 11:18 PM
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
Damon
Sep 26, 2015 04:29 PM
