Fix Standard exhaust or get headers?
Old Dec 16, 2006 | 01:16 AM
xplane's Avatar
Car: 85 camaro sport coupe
Engine: 2.8 MFI
Transmission: v6 700R4 wish it was a 5spd Stick
Axle/Gears: Stock non posi 3.42s
my stock manifolds are warped and just overall crap. they wont seal with the standard steel doughnuts and the soft ceramic ones blow out after about a year, also the gasket where the manifolds mount to the heads blows out every 6 months or so. so far i have replaced the manifold gaskets 4 times and the doughnuts 2 times. i figure it would be more worth my time to spend the money on headers and be done with the problems and get more power to boot.
Also will the iron head 60*V6 headers work with the gen III alum heads? Id like to build a 3.4 with those heads and ECM at some point.
Old Dec 16, 2006 | 07:34 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
id say get the headers. but if youre going to swap to the FWD heads, im pretty sure the pacesetter headers wont work with those.
Old Dec 16, 2006 | 03:32 PM
grimmcs's Avatar
Car: 91 Camaro
Engine: 3.1/3100 in progress...Turbo Soon
The bolt spacing is farther apart on the heads. No they wont work.
Old Dec 17, 2006 | 04:38 PM
69charger383's Avatar
Car: 2005 Lincoln LS, 83' Z28
Engine: 242 DOHC and an empty engine bay.
Transmission: 5R55S, T5 soon to be auto
Axle/Gears: 3.58s and soon to be 4.10s
The RKSport headers will work but they cost a good chunk more.
Old Dec 17, 2006 | 09:01 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
What you want is your y pipe to manifold ends done like a Buick.
Its so strange but with-in GM each brand did its own things.
Buicks don't have donuts.
They just flange the y pipe like a donut and go steel to steel. No leaks, ever.
They also did thing like moving the dizzy to the front for easy access, along with the oil filter and oil pump. So you can change the pump without removing the pan. Its external.
AussiePr0nCar
Mar 6, 2020 04:04 PM
Street Lethal
Apr 30, 2019 12:14 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
dyeager535
Aug 28, 2015 08:10 AM
mustangman65_79
Aug 7, 2015 09:55 PM
