quick newb question
Old Jan 18, 2007 | 02:39 PM
syko's Avatar
quick newb question
I know this is going to sound retarded... How do I set cruise control???? I know it's the little slide switch on the left lever, but that never seems to do anything. Same with the side pushbotton on the same lever.
thanks
Old Jan 18, 2007 | 03:45 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
To set it you set the slide lever in the middle position, that's "on."
Then you press the button on the end to set it.
If it doesn't work, you might have a problem with the cruise computer, Brake switch, Clutch Switch(if manual trans), Actuator, or vacuum source to the actuator.
Old Jan 18, 2007 | 05:53 PM
Project: 85 2.8 bird's Avatar
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
yeah, verify the vacuum lines are good, and also that the diaphram on the cruise thing isn't leaking/cracked.
side note: is there a fuse for cruise?
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
jahblah
Aug 12, 2015 05:54 PM
