will 2.8 from camaro fit in a S-10 with 2.8??
Old Feb 15, 2007 | 07:07 AM
wannafbody's Avatar
Car: 88 GTA
Axle/Gears: 3.27 9bolt
My uncles 2.8 in his S-10 locked up and I cannot seem to find a 2.8 from a truck but there are a few from camaros around here.
Ths truck is a 92 TBI 5 speed. Will i need a motor from a 5 speed? Will it bolt right in?
thanks
Old Feb 15, 2007 | 08:40 AM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Yes it will work fine, they are the same long block.
Just swap over the S-10 specific parts, like intake, oil pan maybe different along with the front cover.
Also make sure you use the correct flywheel/flexplate with the new engine. There was a change in '87 from external balance to internal balance.
Old Feb 15, 2007 | 11:48 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
The base timing cover is the same, but the waterpump is different.
He could also install a 3.1 or 3.4 in it, would just have to bump up the fuel pressure. I use to own an s10 and installed a 3.4 init, so if you need help, gimmie a pm.
Old Mar 3, 2007 | 07:28 PM
talover111's Avatar
Car: 1985 & 1988 trans am
Engine: 350 tpi ; 355
Transmission: 700r4 auto; converting to 6 speed
Axle/Gears: 9 bolt 3:27 posi; 2.73 open
i have a couple if you need one but a camaros will work but you need to change the oil pan, oil pump pick up tube, intake manifold, and valve covers
Old Mar 4, 2007 | 03:08 AM
wannafbody's Avatar
Car: 88 GTA
were are you located? how much?
Frozer!!!
Jan 19, 2024 04:55 PM
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
89lsc
Aug 14, 2015 04:58 PM
matthew911
Aug 12, 2015 09:38 AM
Vintageracer
Aug 11, 2015 08:13 PM
