help help !!!!!!!!!!!
Old Mar 11, 2007 | 08:12 PM
tech1's Avatar
put new puter and timing set in . set timing set secondary timing at 10 and it wont take any throttle at all. i can set timing about 30 to 35 and it runs great . except for a little valve chatter . some one please help me find problem
Old Mar 11, 2007 | 10:40 PM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
You replaced your timing chain and it's off that much?
Are you SURE that you are not a tooth off on your timing chain set up? Something is a tooth off somewhere. Your balancer and your cam are not in agreement I think.
I hope I'm wrong... I have no other explanation for your timing being so far off to run right...
Old Mar 12, 2007 | 02:36 AM
gottfuel's Avatar
Car: only GM,88 camaro, 91r/s camaro, 91
Engine: Clean oil, looks fresh, no leaks
Transmission: Bright Red, never burnt, no leaks
Axle/Gears: currently whining
did you unplug the ecm when you set the timing? also there is a relearn period for the ecm. that can some times take days to be compatable with new characteistics
Old Mar 12, 2007 | 11:22 AM
tech1's Avatar
hey did not know that it could take a little while did unplug static wire . replaced puter , did not replace chip . have great compression . i will take battery off today and let set till tomorrow and plug back up thanks for info you guys are great . need all info i can get thanks again terry
according to my marks im dead on , on the timing marks both in line with each other. will check again . thank you for info . terry
