1990 Firebird V6 3.1L T-Top Auto.
Old Jun 14, 2007 | 08:58 PM
cali firebird's Avatar
i have a 90 firebird 3.1L V6 ive replaced the timing chain, and its tention guide (which was worn to
nothing) ive had the car 2 weeks, spark plugs have orange spark when spark plug is touched to
ground, timing gears are aligned with small dots centered, i smell fuel on the plugs, it sounds like it
wants to start but wont turn over, battery has been fully charged, im pullin my hair out tryn to
figure this out any help would be great before i go bald. fuel pump turns on properly, distrubiter is
rusty but still turns, ignition coil is fine, as u see ive tryed many things and still nothing, this car ran
when i first got it and kinda spuddered to a hualt, has a half of tank of fuel mid grade(shell,
cheveron) , i changed the oil and filter, please help!!!!!
and it was ideling high when i first got it about 2500 rpm in park then 1500 in drive with break applied
Old Jun 20, 2007 | 03:57 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Welcome aboard thirdgen.org.
I'll move this to the V6 forum where you'll probably get better help.
Did you pull the distributor out while you were doing all this work?
Old Jun 20, 2007 | 09:23 PM
jstrdn90rs's Avatar
Car: 90 RS/90 Z-71/73 Vega
Engine: 3.1/5.7 TBI/5.7
Transmission: 700R4/700R4/350turbo
Axle/Gears: 3.23/3.42/3.42
Re: 1990 Firebird V6 3.1L T-Top Auto.
I too own a Cali Car...had it shipped from Sacramento to Arizona..and its a 90 v6 t-top as well.I will give you my opinion and would say you might have a leaky injector(need to run a fuel pressure test) if you disconnected the battery ,you do know these cars need to re-learn idle??..Since I am on the subject of injectors...I replaced mine with the same Multec(stock) ones and am disappointed(having issues) and currently waiting for some Ford injectors to replace them.if anybody reading this has the Ford 15#ers in their v6 can you give me your opinion?.
Old Jun 20, 2007 | 09:53 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
Orange spark is a bit weak... you are looking for a bright electric blue.
Old Jun 20, 2007 | 11:42 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
I would replace the coil and go from there. You want to have a very nice bright white or blue spark. If you're really brave, hold the plug with a set of inculated pliers and hold it about 1 cm away from ground, you should still have a spark. This is risky though and might not feel too good if you get a little far away.
Jorlain
Exterior Parts Wanted
Jun 29, 2017 11:04 PM
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
HoosierinWA
Oct 7, 2015 10:15 AM
jerflash
Sep 22, 2015 09:59 AM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
