Rebuilding for reliability/economy
Old Aug 3, 2007 | 02:44 PM
forkvoid's Avatar
Car: '87 Camaro / '87 Chevy K10
Engine: 3.4L MPFI (soon) / 5.7L TBI
Transmission: 700R4 / 700R4
Axle/Gears: 3.42 / 3.73
Starting my first engine rebuild. I've got a 2.8 out of an '88. Looking for suggestions for parts for ultimate reliability and economy.
1) Is the OE spec cam best for my application, or is there a better one that will not hurt mileage?
2) If the pistons appear fine, is there any need to replace them?
3) The typical wear parts will be replaced(ie, pushrods, rockers, springs, etc). Is there any reason to replace them with something other than OE spec that isn't going to hurt mileage?
4) Any specifics on the best gaskets?
5) If there is no damage, I'm only going to hone the block and heads. Is there a good reason to have a valve job done if the valves do not appear to be bad?
Any other things I should take a deeper look at?
Old Aug 3, 2007 | 02:55 PM
daves12secV6's Avatar
Re: Rebuilding for reliability/economy
u could go with the towing cam for the s10 blazer application.
if the cyls do not need to be bored u can reuse the stock pistons assuming they arent cracked or damaged in anyway.
pushrods and rockers are questionable depending on how much wear they have.though if ur going to change rockers a set of roller/rollertip rockers wont hurt.valve springs and se3als should be replaced.
use a set of victor reinz or felpro gaskets
a valve job is deff a good idea. the valve seat is what makes the valve seal when it is closed,though depending on the condition of valves and seats u can lap tyhem in by hand, but a valve job is a better idea, and typically in exspensive.
on a side note if u look on ebay u can buy reman iron heads very cheap, cheaper then u can get the valve job.springs etc
Old Aug 3, 2007 | 05:06 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
depending on how/what use you plan to use this motor for really depends on the cam.
If the car is mainly in-town, the truck/blazer cam wouldnt be to bad. More low end torque for stop light to stop light. Will do ok for some highway trips.
If your going to be doing a lot of highway trips, Id suggest staying with camaro cam.
roller rockers for sure.
3.1 crank for the extra torque? But then that would also require new 3.1 pistons.
have a better y-pipe made rather then the "t-pipe".
crank pulley
Main thing is going to be tweaking the prom chip to max efficiency.
msd or hypertech coil, good wires, delco plugs gapped right, brass cap/rotor.
Old Aug 3, 2007 | 05:13 PM
forkvoid's Avatar
Mainly in town, with periodic long(200+ miles) highway trips.
Old Aug 3, 2007 | 08:05 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
What would the Y-pipe look like? Would is give the passenger cyl a longer tube before it met with the driver exhaust?
Old Aug 5, 2007 | 03:43 PM
forkvoid's Avatar
What are the specs on this cam? I can't seem to find much reference to it.
The standard OE spec will do fine?
Old Aug 5, 2007 | 07:48 PM
Dale's Avatar
Engine: 350 S-TPI
it would look more like the one that comes with the headers.
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
hartsmike
Oct 2, 2015 07:11 AM
Derrick86
Oct 1, 2015 05:12 AM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
3.8TransAM
Sep 27, 2015 08:37 PM
