Man Down...Time for new car.
Old Nov 18, 2007 | 07:56 AM
  #101
firstfirebird's Avatar
Re: Man Down...Time for new car.
The webbing on the blocks are different. I would experiment on a junk block before trying it on a good engine. Then all you would need is a crank with the notches on the center "timing" journal.
Since I have been trying to make the 60*'s become an intrigal part of the shop, when I get the 3.1 out of the Firebird, I'll see about drilling for the sensor (and making a jig). With a jig, it will be a process simple enough for anybody to do that has access to a drill.
First pic in post #86 shows the webbing being thicker in the area of the sensor. It's located in the center of the block down low in the pass side.
Old Nov 18, 2007 | 09:17 AM
  #102
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
If you can't drill it, then you have to run a trigger wheel like the Buicks. Maybe a Buick balancer can be fitted to the 60* somehow? I have machined crank noses of "weird" engines to run aftermarket SBC balancers. It works as long as you take your modified assembly to the engine shop and have your crank/balancer/flywheel rebalanced. It was a pain in the butt, but when I was done I could then run an aftermarket sbc balancer and crank pulleys, which are much more available. I'm wondering if you can't do that with a 3.1?
How did the older 2.8/3.1 front wheel drive engines run DIS? Did they also have a webbed block?
Does anyone know the technical difference between the FWD and RWD blocks as far as usefulness? Are we just a set of motor mounts away from running an older 2.8/3.1 FWD block? I know the bellhousings match. At most, a slight clearancing for the starter to clear a RWD transmission. What else is the hang up?
I sold an 89 2.8 from a Firebird to a friend who put it in his Citation. I thought he was crazy, but he drove it to work to prove it to me! He said the only thing he had to do was to drill and tap the other side of my block to run his FWD starter. He ran his carb stuff and large cap distributor so the DIS stuff wasn't an option. I am just wondering about motor mount issues because it would sure be easier to score a FWD engine when on a budget rather than trying to mod an existing RWD 2.8/3.1...
Old Nov 18, 2007 | 10:16 AM
  #103
grimmcs's Avatar
Car: 91 Camaro
Engine: 3.1/3100 in progress...Turbo Soon
Originally Posted by KrisW
I don't know, I understand budgets but you ought to be able to get a 3.4 pretty cheap if you're scouring the wrecking yards...
I read what you said about attaching a trigger wheel to the back of the balancer. That's the 3800/3300 Buick type setup. It works fine; I just don't know how you're gonna attach it to make it perfect...
Is it maybe possible to get the measurements from firstfirebird on his 3.4 (or take your own measurements from your crank) and drill/tap a hole in your block to hit the crank sensor that is cast into your crank already?
I already have the DIS pretty much figured out for my set up. I looked around in my area for a 3.4 with no luck. Probubly could have found one but I already had 3100 pistons so I was already leaning tword using my block.
Old Nov 18, 2007 | 10:25 AM
  #104
85berlinetta2.8's Avatar
Car: IROC Z
Engine: 5.7
1995
Engine
Chevy Camaro 3.4,A,6-95,SFI,RWD 160,000 A 05G028 $650 Kress Auto Recyclers USA-PA(West-Hazleton) E-mail 1-570-454-7211 Toll Free: 1-800-582-6336
1994
Engine
Chevy Camaro 000028013 $600 Joe's Auto Parts USA-PA(Sunbury) E-mail 1-570-648-9765
1994
Engine
Chevy Camaro 3.4,AOD,5 94,NEEDS COIL 66,000 A 784868 $575 #1 Morgan Highway Auto Parts USA-PA(Scranton) Request_Quote 1-800-648-1441 Request_Insurance_Quote
1995
Engine
Chevy Camaro 3.4,AOD,EFI,RWD 84,000 A 144592 $550 Triple Nickel, Inc. USA-PA(Chambersburg) E-mail 1-800-933-8627
1995
Engine
Pontiac Firebird 3.4L R-D BLACK 110,447 A UU-382 $550 J & D Auto Recycling, Inc. USA-PA(Manheim) Request_Quote 1-717-273-2890 Request_Insurance_Quote
1995
Engine
Pontiac Firebird 9-94,RWD,EFI,3.4,AT 106,285 A 5835A $550 Sharon Auto Wrecking USA-PA(Mercer) E-mail 1-724-346-4106 / 1-800-346-4109
1995
Engine
Pontiac Firebird 05-95 070204 $450 Red Lion Auto Salvage USA-PA(Red-Lion) E-mail 1-800-288-6234
1993
Engine
Chevy Camaro 122,000 NO SMOKE *25800035 $450 Ritenour & Sons Auto Wrecking USA-PA(Ellsworth) Request_Quote 1-724-239-2601 Request_Insurance_Quote
1994
Engine
Chevy Camaro 11-93,FWD,SFI,3.4,AO D, 070578 $400 Costy's Auto Parts USA-PA(Mansfield) E-mail 1-800-424-7772
1995
Engine
Chevy Camaro RWD,SFI,3.4,AOD, 060613 $400 Costy's Auto Parts USA-PA(Mansfield) E-mail 1-800-424-7772
1995
Engine
Chevy Camaro RWD,SFI,3.4,AOD, 060799 $400 Costy's Auto Parts USA-PA(Mansfield) E-mail 1-800-424-7772
1994
Engine
Pontiac Firebird 3.4 121,000 3618 $350 B & B Salvage, LLC. USA-PA(Mount-Joy) E-mail 1-717-653-2685 / 1-717-653-7343
you can do a search on why the fwd blocks wont work.
Last edited by 85berlinetta2.8; Nov 18, 2007 at 10:28 AM. Reason: Automerged Doublepost
Old Nov 18, 2007 | 10:54 AM
  #105
grimmcs's Avatar
Car: 91 Camaro
Originally Posted by 85berlinetta2.8
1995
Engine
1995
This is the closest one for me. About 45 min away. Although this wasnt up when I started collecting my parts Oh well, I already have enough parts to get me started with my 3.1. Ill put the parts on and shoot some pics once I get the engine out, which should be with in the next week or two.
Old Nov 18, 2007 | 11:01 AM
  #106
KrisW's Avatar
Engine: 2.8/TBI/TPI
That is an awesome list above,
85berlinetta2.8, where did you search for that stuff? Some kind of parts locator?
Old Nov 18, 2007 | 11:03 AM
  #107
grimmcs's Avatar
Car: 91 Camaro
from the looks of the list it looks like it came from car-parts.com
Old Nov 18, 2007 | 11:19 AM
  #108
Car: IROC Z
Engine: 5.7
yup
Old Nov 18, 2007 | 02:12 PM
  #109
I bought a complete 3500 this week, for the same price I paid for a top end only a couple of months ago - through car-part.com
Grim, if you get a 3.4, not only will the swap be simpler, but you can upgrade to a 3500 top end a lot easier later.
Old Nov 18, 2007 | 02:23 PM
  #110
Car: IROC Z
Engine: 5.7
\quote...somthing about replacement and displacement
Old Nov 18, 2007 | 02:59 PM
  #111
grimmcs's Avatar
Car: 91 Camaro
I may upgrade to a 3.4 later, but for now Im going to see what my 3.1 can do. Seeing how I have the 3100 pistons, an external DIS trigger wheel assembly, and my money tree out back is has begun hibrinating for winter.
Old Dec 10, 2007 | 05:13 PM
  #112
grimmcs's Avatar
Car: 91 Camaro
Inching along...
Got the coolent hoses off...
Got the radiator out...
Looked like a tree was hiding his leaves in there...
And I got the AC radiator(condensor?) out...
Found some surface rust under there...not to happy about that, but it should be able to be fixed.
Next time I spend time working on the car I should be taking the engine out. Hopefully by my day off this rain stops
Old Dec 10, 2007 | 05:26 PM
  #113
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
The project is creeping along nicely. I know that you don't have lots of time. So the motor is comming out next if weather allows and a turbo 3.1 going in correct?
Old Dec 10, 2007 | 05:47 PM
  #114
grimmcs's Avatar
Car: 91 Camaro
I tinker after work a little and on my days off. I prefer to work on it when Im the only one home...less people telling me "you know I wouldnt do it that way" or "whats that?", "whats that do?", "why are you doing that?".
What Im planning on doing a full rebuild with 3100 pistons, 3X00 top end, headers, turbo w/intercooler, a nice size cam, rebuilt tranny, and posi.
And yes as long as the weather cooperates, and I have help, I want to pull the engine/tranny this week.
  #115
Turbo 3.1/3100 hybrid
This is gonna be a mean sombitch
Old Dec 10, 2007 | 05:50 PM
  #116
grimmcs's Avatar
Car: 91 Camaro
Thats what Im hoping
Im going to smooth out the 3400 plenum and I want to put something on the top. I know a guy that airbrushes. So what design/words could I put on there? Oh and the plenum will be black.
Old Dec 10, 2007 | 07:21 PM
  #117
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Get 3100 with flames on them for the manifold.
Old Dec 10, 2007 | 08:01 PM
  #118
You mean like this? (unfinished still)...
I also polished some valve cover to match (going on a customer's car)...
Old Dec 10, 2007 | 08:19 PM
  #119
grimmcs's Avatar
Car: 91 Camaro
Exactly. I will probubly get it to that point and than paint it black. Im not much of a flashy person...Chrome/polished aluminum is not really my thing. I was thinking of a tall while Camaro symbol down the middle or a white Chevy BowTie down the middle. Something simple and plain yet eye-catching.
Old Dec 11, 2007 | 10:59 PM
  #120
grimmcs's Avatar
Car: 91 Camaro
So I have tomorrow off and it looks as thought the rain is going to break and stop by noon. Ive been talking to a guy I work with and he keeps telling me that I can pull the engine solo...this coming from a guy who use to make drag cars. He recently sold a Dodge Demon with a 5xxci engine
Old Dec 12, 2007 | 01:49 AM
  #121
Xoferif's Avatar
Car: '91 Camaro RS
Engine: 3.1L
Yep, it's a small engine...comes out nice and easily...it's really only a one man job, but it's nice to have an extra set of eyes.
I never even had to take off the hood to get it out or to put it in...it cleared...barely...and I never removed the radiator as there's plenty of room in there, and I wasn't pulling the trani with the engine. Love how easy it is to work on these engines.
Btw, I think a white, Chevy bow tie would be a nice touch....but it's a GM engine....so, I think a Camaro symbol would be more fitting.
Old Dec 12, 2007 | 01:07 PM
  #122
slow_90firebird's Avatar
Car: 90 Firebird Formula
Engine: LO3
Axle/Gears: 3.08 one wheel peel
Hey, I know you say that the FWD blocks won't work in the RWD cars, but will the top end?
I used to be on mymonte.com all the time and there was a guy that made really nice stuff for the 60* motors. Everyone on the board had good things to say. His site was www.milzymotorsports.com
Old Dec 12, 2007 | 01:30 PM
  #123
92RS(real slow)'s Avatar
Car: 92 RS(sold) 1989 IROC-Z
Axle/Gears: ones that turn
looks like your making some great progress I love watching other peoples projects keep up the great work
Old Dec 12, 2007 | 02:39 PM
  #124
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
You can get the FWD blocks to fit under the hood. THe topend swap has been done many times and is well documented.
Old Dec 12, 2007 | 04:47 PM
  #125
grimmcs's Avatar
Car: 91 Camaro
Well guys, I cant believe what I did today...
I ran into a few "kinks". The engine hit the firewall a little and left 1 dent and a few scratches. And I couldnt get 1 wire off of the starter, so in my fury I ended up cutting it....I got a little frustrated. I have tomorrow off as well, so I plan to seperate the engine/tranny and get the engine on the stand. Oh and my bro ended up helping. So now i have to buy a case of beer...and share it
Oh and I have a question. At the end my brother took the relief screw all the way out of the pump on the engine hoist and out came oil . It was an accedent and he hasnt worked with cars before so I didnt flip out. Is there a way to refill it or do i need to get a new one?
Old Dec 12, 2007 | 04:55 PM
  #126
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
I be doing that in the next few months except I only have a weekend to get the motor in and the 3.4 in. Any tips for getting the motor out?
Old Dec 12, 2007 | 05:02 PM
  #127
grimmcs's Avatar
Car: 91 Camaro
Plug the tailshaft on the tranny. I was told that a bag secured on there was good........nope. If this is a daily driver than it might be tough to get it torn out and a new one back in in a weekend. That took me about 5-5.5 hours(my first engine pull) to pull the engine. So if you have to strip the ould one, pull it, drop in a new one, and put it back together so you are going to have to really devote some time.
Mabye once my head clears I can give a few more detailed tips.
Old Dec 12, 2007 | 05:05 PM
  #128
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
The 3.4 I'm droppig will almost be complete. The only thing that I would have to swap are the accessories, fuel rail, and tranny. I might wait till spring break though so that I have a week to do the swap and work out any bugs that might surface.
Old Dec 12, 2007 | 07:36 PM
  #129
I wouldn't buy from Miltzy. I've seen their port work.
Either buy from 60DegreeV6 (Ben) or 60DegreeInclusive (Me).
Looks like you handled it well. Actually is easier to pull the tranny and engine together, but it's tough sometimes to get them bolted back together out of the car.
Also you had the hood pulled due to the rust, correct? I'm going to pull just the engine, and bolt the shortblock back in so those two top bell housing bolts are easy - hood is staying on.
Can't wait to see your baby fly this summer!!! Looks like I have some competition, lol.
Last edited by firstfirebird; Dec 12, 2007 at 07:41 PM. Reason: Automerged Doublepost
Old Dec 12, 2007 | 09:02 PM
  #130
grimmcs's Avatar
Car: 91 Camaro
Thanks. I had to take the fenders off to get to the rust. So in order to do that the hood had to come off. I dont think I could have gotten the engine and tranny out with the hood on. Just the engine...probubly doable with the hood on.
Also I am planning on getting a rebuilt tranny because mine has a little slippage. Figured nows a good time to get a rebuilt one.
That makes two of us.
Old Dec 13, 2007 | 08:12 PM
  #131
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
I just saw the pic of the injectors on the first page, just curious why 8 injectors?
Old Dec 13, 2007 | 09:26 PM
  #132
grimmcs's Avatar
Car: 91 Camaro
^^It came in a set of 8. They are V8 injectors
Old Dec 13, 2007 | 09:56 PM
  #133
bl85c's Avatar
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
When you have a trans built you should consider improving it a bit. The 60* trans retained the 27 spline shaft and most of the associated hardware throughout it's use in 3rd gens, so needless to say it's not the strongest trans out there. Take a look at this thread I started a while ago. ->
www.thirdgen.org/techboard/transmissions-drivetrain/436336-improving-early-th700s.html
It's intended for pre- '87 th700's but applies to just about any th700. If you're going to shop for your own parts I highly recommend patc.
Old Dec 15, 2007 | 07:41 PM
  #134
grimmcs's Avatar
Car: 91 Camaro
Well after taking a couple days off to recoupe from the engine pull, I got the engine/tranny seperated...
Got the engine on the stand...
And the tranny into the corner...
...just in time to get tthe garage bay cleared for my moms car before a nasty freezing rain storm.
Oh and I found out that the rear camshaft cover gasket has been leaking. Eather way, this engine was do for a rebuild.
Old Dec 16, 2007 | 06:17 PM
  #135
grimmcs's Avatar
Car: 91 Camaro
Started into the engine today.
Got the LIM off...
Took off the driver side head.......
Took off the pass side head...
And a shot of what it looks like now...
I looked at the cylinder walls real quick (where I could see) and it dosent look like there is much, if any, scoring. Besiders a few bad gaskets, the engine still looks pretty good so far.
Oh and the intake gaskets were Felpro. So I know that, at least, the intake has been removed.
Old Dec 16, 2007 | 08:20 PM
  #136
Spike-Z's Avatar
Car: IROC-Z
Engine: LSx
Axle/Gears: Fabbed 9"
Car looks pretty solid for a LSx swap!
Old Dec 16, 2007 | 10:37 PM
  #137
He should be running a sweet motor when this is finished. Nothing like the look on someone's face when they just got beat by a v6. The stock 3100 heads he has should be flowing about 180CFM if he doesn't port them. Add a turbo and it should be a 300+hp engine (conservative) - the shortblock weighs less then 200lbs, and the top end weighs about 45 (yes, I have weighed them). Nothing wrin with an LSx, but you are in the wrong section if you want to talk someone into swapping a V8. He's got a nice collection of parts already to potentially make this a 11-12sec v6 (providing susopesion/traction upgrades).Chris, All the 660's I pulled apart had good looking cyl walls and the cross-hatches are still appaprent (even over 100k). They all also have that nasty carbon ring at the top of the bore (also note the extra carbon on number 5 and 6 pistons). Hone them, and you should be fine. Make sure you clean the block really good after every process (unless you are having it hot tanked). Chack your cam bearings now while they are easy to get to, but if your oil was changed on a regular basis, they should be good (cam-priority oiling in the Gen1 blocks ). PM me if you need help with any details, since I just finished a Gen1 shortblock, but looks like you are moving along nicely How's the rust situation? Is your friend going to help?
Old Dec 17, 2007 | 06:22 AM
  #138
grimmcs's Avatar
Car: 91 Camaro
I thought about doing this but decided against it for 2 reasons. I want to build a fast v6 and I dont have the money for that swap.
Ive been looking into changing the cam bearings, and I keep finding that its best to have a shop do them. But summit had a tool that can do it. Ill have to see if mine are sill good.
And the rust...car is still in my garage. My friend told me he can fix the rust and paint the car for about $2000 +/-. Hes giving me a BIG discount. He wanted the engine out before he does anything. Now I just need to get him out here to get a better look at it.
Old Dec 17, 2007 | 12:29 PM
  #139
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
^ Coming along very nicely Grimm, how are your fingers feeling....?
Old Dec 17, 2007 | 02:13 PM
  #140
grimmcs's Avatar
Car: 91 Camaro
Thanks, and my fingers/hands feel great. All the cuts remind me that they are still there.
Old Dec 18, 2007 | 03:15 PM
  #141
grimmcs's Avatar
Car: 91 Camaro
Had a pretty productive day. First off I spun the engine upside down and this fell out of somewhere...Im guessing its for the oil pump...
I also knowticed that I must have bottomed out and hit the oil pan...
I got the pan off, oil pump off, crank and water pump pulleys off, balancer off, pistons out...
Went to take off the water pump, and this happened to 2 bolts...
Anyone know how to get these out when stripped?
And finally a pic looking into the cylinders...
Old Dec 18, 2007 | 03:44 PM
  #142
Xoferif's Avatar
Car: '91 Camaro RS
Engine: 3.1L
There's a hole in the rear main cap that that metal rod god goes into...as you suspected, it powers the oil pump.
As for the stripped hex screws...not sure...all my bolts on my 3.1 were sockets...I'm grateful for that. Did you try allen wrenches?
Old Dec 18, 2007 | 05:05 PM
  #143
grimmcs's Avatar
Car: 91 Camaro
I tried vice grips but the top of the bolt is tapered so they kept on slipping off.
Old Dec 18, 2007 | 05:14 PM
  #144
enswrob's Avatar
Car: 89 Firebird
Engine: 2.8L out of a 89 camaro
Transmission: 5 speed
Axle/Gears: ?
actualy that shaft that fell out connects the oil pump to the dizzy
Old Dec 18, 2007 | 05:41 PM
  #145
I replaced my waterpump torx bolts with ones from a 3.4 with hex heads.Try taking the next size up and hammering it in there. One it's jambed in there really tight, turn them slow. Also heat on the block will help.Looks like you didn't have the perfect size, it's an odd one (can't remember off the top of my head and out of town to look in my toolbox) - it doesn't come in the regular sets.
Old Dec 18, 2007 | 06:58 PM
  #146
grimmcs's Avatar
Car: 91 Camaro
It was actually the right one. It had a really good fit...hat to wiggle it in there. I started to twist it with my rachet and before it even moved it popped all the teath out. Ill try to use the nest size up tomorrow...also my dad has a set of normal hex bolt, rounded head, removers that I will try tomorrow as well.
I also want to replace them with normal hex bolts when Im done.
Old Dec 18, 2007 | 09:56 PM
  #147
fictmich's Avatar
Car: 1991 firebird/1990 firebird
Engine: 3.1
Axle/Gears: 3.23:1
If you have to you can grind off the head of the bolts (like they're any good to you now anyway) then you can get the water pump off. Then all you need is a vice grips, penetrating oil, and a torch.
Old Dec 19, 2007 | 02:31 PM
  #148
nixon5's Avatar
Car: 86 F-Bird
Engine: 2.8L v6
usually when i strip a torx bolt i just bust out the dremel with a cutting wheel and turn it into a flathead screw but it looks like you might need to hammer in a bigger size.
Old Dec 19, 2007 | 08:16 PM
  #149
It was actually the right one. It had a really good fit...hat to wiggle it in there. I started to twist it with my rachet and before it even moved it popped all the teath out. Ill try to use the nest size up tomorrow...also my dad has a set of normal hex bolt, rounded head, removers that I will try tomorrow as well. I also want to replace them with normal hex bolts when Im done.
Grimm, this used to happen to us all of the time. Just file down the rounded side of the bolt, do this on two opposing sides, this way the vice grip can grip it properly. Once the vice grip is on nice and tight, add an extension to the vice grip (like a single tire iron) for leverage, and that bolt will break loose immediately....
-Gaspar
Old Dec 20, 2007 | 10:16 AM
  #150
grimmcs's Avatar
Car: 91 Camaro
Thanks for all the tips. I hammered in a bigger size, it griped it, and rounded the middle even more. So at that point I decided to just grind off the heads of the bolts...
At this point I grabbed the bolts with the vice grip and they twisted right out Although I ended up gouging the water pump. But I guess it would be good to buy a new one anyways.
Got the timing chain cover off to reveal an old timing chain...
Took the chain and cam off/out. The cam bearings have 1 rough spot on each. They arent destroyed but seem bad enough that I dont want to test them.
The crank is ready to come out...
And the crank is out...
