Questions about going to 3.73 gears.
Old Aug 18, 2007 | 12:11 AM
Bazookajoe254's Avatar
Car: 86 Firebird
Engine: 2.8 V6
I put 3.73 in the title just becuase I see that alot of people seem to like those. Maybe this answer is going to be more involved than I'm anticipating, but...
What all is involved in swapping out the stock gears and putting in something like 3.73s? Is this a challenging thing to accomplish?
Also, what kind of changes would you see over a stock 1986 MPFI bird's gears?
Like MPH compared to RPM?
Old Aug 18, 2007 | 02:33 PM
ossseo28's Avatar
Car: 1992 camaro
Engine: 3.1 v6, CAI
Transmission: t5
Axle/Gears: eaton posi
Re: Questions about going to 3.73 gears.
the 3.73 is a posi rear end i'm pretty sure. but i'm not a mechanic so i'm not that sure. the only thing you gain is traction, and i'm pretty sure u don't gain a higher top speed if thats what your asking.
Old Aug 18, 2007 | 03:07 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Originally Posted by Bazookajoe254
What all is involved in swapping out the stock gears and putting in something like 3.73s? Is this a challenging thing to accomplish? Also, what kind of changes would you see over a stock 1986 MPFI bird's gears? Like MPH compared to RPM?
Specialized tools are required. The install might be best left to a pro.
You probably already have 3.42's, so you'll lose some top end with 3.73's and RPM's, of course, will increase (detrimental to gas mileage as you can imagine). All things considered, I'd stick with the 3.42's, if indeed that's the gear set you have.
JamesC
Not all 3.73 rears have posi.
Old Aug 19, 2007 | 12:43 AM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
It won't be posi unless he switches in a posi carrier too.
If you're just swapping gears, then leave it to a pro, you have to have a pinion depth guage to get the pinnion shimming done right because if that's off, it screws everything else up. Most gear manufacturers recommend that you set [pinion depth to a +/-0.005", that's really close. Not something you want to eyeball.
Than you have to set the carrier bearing preload and backlash. All this has to be done as close to perfect as possible or you'll get a rear-end whine from the gears...ask me how I know...
Now, if you're swapping out the entire rear end and housing, then it's easier since they'll come already built and it's just a swap-out operation, unless of course, you put new gears in, then you're in the same boat as you are if you just swapped the gears in yours in the first place.
Old Aug 19, 2007 | 12:47 AM
Car: 86 Firebird
Engine: 2.8 V6
Eh. Nothing at all like what I pictured. I've learned to not expect anything easy when it comes to my car .
Thanks for the info guys. I was mostly curious.
hectre13
Dec 11, 2023 08:14 AM
Orr89RocZ
Oct 7, 2015 12:47 PM
Irocguy01
Sep 28, 2015 02:03 PM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
