3.1L Failed NOX
Old Aug 23, 2007 | 08:50 AM
The White Knight's Avatar
Car: 1983 Trans-Am
Engine: 305 5.0 LG4
Transmission: 200C 3 Speed
Axle/Gears: 2.93 Open Diff
3.1L Failed NOX
Did Etest, last july passed PERFECT
did one yesterday for plate renewal, failed NOx (435 limit, got 690) everything else is like WAY low and awesome..
Now the EGR, Its digital, I unplugged it and drove home, car drove same as it does now, no change, Im thinkin its not working, what usually happens to this expensive egr valves lol?
I got a chance to get free one from g/f's uncle so Im putting it on and retesting, but i got no Engine codes, and like I said plugged in or not no change, car runs good all the time so Idk, no stalling or hesitation or surging.
Anyone shed any light
(1992 RS 3.1 Auto)
Old Aug 23, 2007 | 09:03 AM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
Re: 3.1L Failed NOX
You shouldn't notice any drivability difference if the egr is working correctly. If you unplug it, it won't feel any different than if it were working.
Since you can get one, I would stick it on since you don't have the stuff to actually make sure it is working properly.
You can alos try installing a new O2 sensor. You'd be surprised how much an O2 sensor affects NOx. There have ben many, many cars that I have repaired for NOx failures that all it took was a new O2 sensor.
Old Aug 23, 2007 | 09:14 AM
Car: 1983 Trans-Am
Engine: 305 5.0 LG4
Re: 3.1L Failed NOX
Ya, o2 can cause like double the limit? Hmm, Ill try EGR and retest, then Ill see whats up, and do o2 if needed!
Everything else is so low though, like HC and CO are next to nothing, perfect readings for my 327,000km 3.1 lol
But the nox, and it was PERFECT last year...
Where is the o2 in this thing (used to my 350 lol :$)
Old Aug 24, 2007 | 02:48 PM
Car: 1983 Trans-Am
Engine: 305 5.0 LG4
Re: 3.1L Failed NOX
Well damn
Put my buddys newish Egr on, went from 690 to 1756!!! Im thinking that this thing is not even working now, Im gunna trace wires, limits 450, thats all I changed, before it was 690, ALL i changed was EGR and it jumped to 1756, Any ideas
Old Aug 27, 2007 | 01:54 AM
FAST RS's Avatar
Car: 1991 CAMARO 1968 FIREBIRD
Engine: CAMARO 3.1L FIREBIRD 455
Transmission: CAMARO 700R4 FIREBIRD TH-400
Re: 3.1L Failed NOX
I had similar numbers turned out to be the O2
HoosierinWA
Oct 7, 2015 10:15 AM
racereese
Oct 3, 2015 03:46 PM
6998poncho
Sep 25, 2015 02:56 PM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
