Converting to rear disc brakes.
Hi all, i want to swap my rear drum brakes to disc brakes, but i dont want to change my whole axle for something lika a fourth gen axle, so can it be done?
, and still keep my stock axle
Car: '88 Trans Am
Engine: 5.7L TPI
Transmission: Slushbox
Re: Converting to rear disc brakes.
sure can i have done a few
you need the backing plates,rotors,calipers and all bolts associated,depending on the brakes to use you will need the rear brake lines as well.
if you have an 84 or older car you MAY have a problem with the brake line fitting at the rear of the car where it goes into the rubber line it is a different
size fitting,if you have a HOSE shop they can make it for you for 20.00 or so.start to finish should take you about 3 hours can take more.
i have a set of Ls1 backing plates left over for 75.00 shipped if interrested.
Thanks a lot!, but the shipping is going to cost me more than the parts hahahaha, currently i live in mexico, and forgot to mention but i have a 91 bird
Car: 89 Camaro RS
Engine: 2.8L
Car: '88 Trans Am
Engine: 5.7L TPI
oh dang!
well atleast you had them available to you.
the info should help you to get the disc set up you want though
i can get newer fourth gen parts here, but there aren't many third gens, im actually in a f body club, its in spanish but its a very big forum, www.camaro-transam.com, so theres were ill get son ls1 brakes for the swap, thanks a lot
hectre13
Dec 11, 2023 08:14 AM
1992 Trans Am
May 10, 2023 07:19 PM
sailtexas186548
Jan 19, 2016 12:21 PM
