FS: 19# Injectors (Turbo and H/P only)
Old Sep 14, 2007 | 12:42 PM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
For those who need them, I have a full set of 19# injectors. These came off of a 305 and I can't use them because they mess with my A/F ratio too much. I don't have 8, mind you, only 6, which is why I am offering this to the V6 crowd. These won't work with a 2.8 or 2.8 PROM, as the A/F ratio will need to be recalibrated. AFAIK, they all work. Their impedance is within tolerance, but I have no other way to test them.
Best offer gets them. I will also accept the trade of either a pair or set of 3.1 stock injectors.
Mods, if you feel this needs to be moved, then be my guest...
Old Sep 15, 2007 | 06:08 PM
firstfirebird's Avatar
Re: FS: 19# Injectors (Turbo and H/P only)
19# should run fine with a MAF computer (may have to turn down the FP by a couple PSI). Have you tried them?
Old Sep 16, 2007 | 08:53 AM
Engine: 2.7L V6
Axle/Gears: 4.41
Yes, I tried them. I made a single, 375 mile run home (read as: ALL highway) with them installed, and the car ran like crap, much like it did when the 3.1 was first dropped in. Extremely rich. I don't have an AFPR nor the means to get one, so I can't use these injectors at this time, and I need just 2 3.1 stock injectors to replace mine (2 clogged injectors currently running on cyls 3 and 4) while I either send them out to be cleaned or I get an AFPR.
Old Sep 16, 2007 | 09:46 AM
AFPR that goes into your return line can be had from ebay for pretty cheap. I have one I'm not using anymore...
https://www.thirdgen.org/forums/v6/4...tuff-sale.html
New2Chevy
Sep 28, 2015 12:35 AM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
Nick McCardle
Sep 10, 2015 08:36 PM
