Is this a problem? It doesn't smell like its drenched, but when you open the hood, you can lightly smell gasoline and its definitly from the smog canister.
I read, I think in a Hayne's manual, that the filter should be replaced if they smell of gas. Is this really something that matters?
Mikz86TA
close
Yes. Replace the filter. Purolator makes it and its availible cheap at most auto parts stores.
You should also check the purge valve to make sure that it's working correctly.
I was wondering....how do ya check to see if the purge valve is working?
Ken
Ken
I second that question. How do I check it? And where exactly am I gonna find it? On top of the canister?
