2nd Radiator Cracked!!
Car: 1987 Camaro
Engine: 3.4 Liter
Transmission: 5 speed
Axle/Gears: stock
I have replaced my radiator twice this year and I'm not sure what the problem is. I'm thinking since the water pump is in need of replacing this could have caused the issue. But needless to say I have repalced my radiator twice this year. Just curious if anyone else has had this issue before and if so what did you do to resolve it.
Thanks in advance!
Derick
Thanks in advance!
Derick
Car: 1987 Camaro
Engine: 3.4 Liter
Axle/Gears: stock
Re: 2nd Radiator Cracked!!
My pops said the same thing. Going to get a new rad tomorrow and a new rad cap also.I hope thats the issue b/c I am getting tired of replacing them. Thanks for the input thats good backup to pops diagnosis.
Car: 1987 Camaro
Engine: 3.4 Liter
Axle/Gears: stock
Car: 1987 Camaro
Engine: 3.4 Liter
Axle/Gears: stock
New radiator is in and took it for a drive tonight. On the way back to the house the over flow bottle starting bubbling over again. Not sure what the issue can be now b/c i got a new cap also with the rad. I'm gonna change the thermostat tomorrow and see what happens.
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
If you are cracking radiators that quickly, then I would seriously suspect a problem with a head gasket seal. What tends to happen is that you get a breech between a cylinder and a water jacket and the compression forces into the cooling system, which are not desined for a sudden 180 psi.
I have seen gaskets break and act as a kind of one-way valve, allowing compression pressure to enter the cooling system, but not letting coolant into the cylinder.
Does your car run a little rough on initial startup in the morning then clean up?
Car: 1987 Camaro
Engine: 3.4 Liter
Axle/Gears: stock
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
thata probably just your cooling system purging out all the air in the system.
Car: 1987 Camaro
Engine: 3.4 Liter
Axle/Gears: stock
Figured out the issue. Fan relay sensor went bad and car was over heating. Ran a switch from inside to bypass it. Pictures to come but problem solved.
blackz281le
Jan 11, 2016 07:51 AM
gta892000
Sep 16, 2015 12:37 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
