intake plenum
Old Oct 19, 2007 | 11:18 PM
poppn's Avatar
Car: '85 Firebird, '74 Nova
Engine: 2.8, 5.7
Transmission: T5, TH350
Axle/Gears: 3.42 open, 3.08 open
intake plenum
Would it be alright to use something like a silicone gasket maker in place with an existing old intake gasket on the top intake plenum?
Old Oct 19, 2007 | 11:44 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
Re: intake plenum
The problem is that they are both machined surfaces. If everything is true, then it tends to squish out the silicone and then it's like it was never there.
I would just spend the $16 and get a new gasket set. It's easier and will be better in the long run.
You could try it though, I'm sure there have been some people here that have had some sort of success with it.
Old Oct 20, 2007 | 12:44 AM
poppn's Avatar
Engine: 2.8, 5.7
Re: intake plenum
Would this be the right gasket set to purchase? Do they make just the plenum gaskets separate?
http://www.partsamerica.com/ProductD...pe=102&PTSet=A
Old Oct 20, 2007 | 12:59 AM
bl85c's Avatar
Car: '85 maro
Engine: In the works...
Transmission: TH700 R4
Axle/Gears: 3.73 posi
Re: intake plenum
You can get the plenum gaskets individually. Or you could just use some silicone gasket maker, but don't use them together. Solid gaskets seal much better by themselves.
Bubbajones_ya
Jul 6, 2024 08:32 PM
Nick McCardle
Sep 10, 2015 08:36 PM
toronto formula
Sep 10, 2015 07:31 AM
e3pres
Sep 9, 2015 01:51 PM
