Useful links for v6 guys
Old Nov 17, 2007 | 04:32 PM
ohiotemplar's Avatar
Car: 1992 Camaro RS V6
Engine: 3.1 V6 MFI
Axle/Gears: 3.23 stock
When shopping for upgrades for my car, I found it very hard to actually find much. I'm alway in one thread or another asking for a link or part number. Through some research here's what I've got so far. I hope you all add to it.
Wonderbar - drastically improves handeling by tying the fron subframe together
http://www.lmperformance.com/18596/7.html
Energy Suspension Greaseable Sway Bar Bushings 35mm and other sizes - I've heard that the 35mm fits the 36 mm ws6 front sway upgrade. There are always some on ebay
http://www.lmperformance.com/3127/.html
All of the rest of your poly buching needs for handeling improvement
http://www.andysautosport.com/chevro...sion/bushings/
1LE end link kit and alot more great steering improvments for cheap
http://www.top-downsolutions.com/ind...5fc0777d2f83a3
Quality Tranny rebuild kits, service and upgrades for any budget
http://www.bowtieoverdrives.com/cata...SUBCAT&CATID=B
Smog pump delete (also called airpump) - clear your engine bay and add HP
https://www.thirdgen.org/serpentine
Additive to keep your weather stripping young (great product, I love it)
http://www.shipstore.com/SS/HTML/AME/00-INDEX-AME.html
According to Muscal car magazine, this is the best steering box we can get
http://www.parts123.com/parts123/yb....Z5Z5Z50000136b
Replace those leaky Pingel fuel injectors - there are alot of mixed feelings on here about accel, but they are the only ones I could find
http://store.summitracing.com/egnsea...8&autoview=sku
Adjust your TV detent cable - no tools needed, takes 30 seconds
https://www.thirdgen.org/detent
B&M Kickdown valve - keeps your 700R4 tranny from constantly shifting between 3rd and 4th gear at highwya speeds. Save your mileage and your tranny.
http://store.summitracing.com/partde...0&autoview=sku
Want a quiet ride like a new car without adding alot of weight? Try this:
http://www.b-quiet.com/
New dash pads and door panels
http://www.coverlaymfg.com/index.php...%5Bmode%5D=any
New motor mounts - Poly upgrade
http://store.summitracing.com/partde...5&autoview=sku
IAC and TPS maintenance for smooth consistant idle
https://www.thirdgen.org/tpimod2
A good mild camshaft upgrade that everyone has something good to say about
http://store.summitracing.com/partde...4&autoview=sku
Want cruise control with presets that easyto install? These are alway cheap on ebay
http://cgi.ebay.com/ebaymotors/NEW-A...spagenameZWDVW
RAM AIR functional hoods
https://www.ramairhood.com/store/scr...p?idproduct=15
60 MM and up Throttle bodies - helps your car breath easier for more power. But honestly, only with a new intake manifold.
http://mrzperformance.vstore.ca/prod...a01bbedf9db8fa
Tuning software to tune your car with your laptop - FREE
http://tunerpro.markmansur.com/downloadApp.htm
ALDL Cable to plug your laptop into your car
http://www.moates.net/product_info.p...roducts_id=127
that's all I can find so far. If there are cheaper or better alternatives for my research, please feel free to add it.
Old Nov 17, 2007 | 04:43 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
Axle/Gears: 3.42 open diff
Re: Useful links for v6 guys
Good writeup of parts, there is already a stickey at the top of the page with lots of parts listed on it.
Old Nov 17, 2007 | 04:52 PM
Engine: 3.1 V6 MFI
I know, I this is better for noobs like me who came into this know nothing. The "parts for 60* motors" is still greek to me.
Old Nov 17, 2007 | 10:35 PM
BobItzaboy's Avatar
Bench flowed ported heads (Not homemade jobs- actual match cylider CFM and pressures.- SuperSix Motorsports.
Underdrive crank pully (Use crank pulley only, Not alternator set) -ASP
Holley TPI adjustable fuel pressure regulator
Greg @ PF&E (Performance Fabrication & ENgineering Specialize in the GM C5-RSR race Vettes) for Stainless steel semi tuned headers. Not technically legal- but there are ways around this (Thats all I will eloborate)
Hypertech Coils- 53,000 volt coil
NOTE- USE AC DELCO ignition modules (they are workhorses- the best your money can buy!!!!
edit: What the helll, my post got cutoff. I had about 3 times this listed- I will do it again later.
Old Nov 24, 2007 | 10:22 AM
Engine: 3.1 V6 MFI
bob, for the headers, how would anyone know they weren't legal? Great addition btw! I was hoping for direct links so it would be easy for people to shop quickly and compare prices, but still, great stuff I havn't been able to find. Lets keep it up! - Nate
Old Nov 24, 2007 | 10:34 AM
grimmcs's Avatar
Car: 91 Camaro
Engine: 3.1/3100 in progress...Turbo Soon
Here is what my set looked like, before I had them cut up to work with a turbo. This was the prototype set. They are also not smog legal because they have no hookups for the AIR pump.
I dont think PF&E has a website (I could be wrong), but I have their number and address around here somewhere. Ill have to find it.
Old Nov 24, 2007 | 01:31 PM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
^^^Those PF&E's are better then pacesetter? I have seen a few sets but I don't think that they are mass produced like Pacesetter's but they more equal length than them. I do know that F_F is planning on making some LTs for out cars and here I am about to pick up a set of LTs from another guy.
Old Nov 26, 2007 | 05:27 AM
Engine: 3.1 V6 MFI
Can someone please post a link for a Trans-Go shift kit and better/vette servo? I'm not having much luck...
Old Nov 26, 2007 | 06:57 AM
2.8RS's Avatar
Car: 89 V6 Camaro
Engine: 2.8
I don't think that transgo comes with the corvette servo
http://www.transgo.com/sk_generalmtrs.php
These guys have alot for the 700R4:
http://www.bteracing.com/Products.as...ts=-1156399622
(shift kit, servo, lots more parts)
Fanatic1074
Oct 3, 2022 05:57 AM
JMT73
Oct 11, 2015 11:57 AM
SavingPvtEric
Sep 29, 2015 05:59 PM
dbrochard
Sep 25, 2015 04:56 PM
Angie Coots
Sep 23, 2015 07:42 AM
