air pump bypass
Old Jan 13, 2008 | 07:07 AM
86v6CP's Avatar
air pump bypass
I am preping my v6 for competition and have no use for the ir pump or the AC. ditching the AC is easy but the airpump shares a serpentine belt with the water pump. Does anyone have a number for a shorter belt that would fit with the Air delete?
Old Jan 13, 2008 | 07:42 AM
89transam*pearl's Avatar
Car: 89 T/A
Engine: LB9
Transmission: W/C T-5
Axle/Gears: 10 bolt posi, 3.73 Richmond Gears
Re: air pump bypass
If you do a search in the Engine or Exhaust forums on removing A.I.R. or deleting A.I.R. the belt size is in one or more of the threads.
Old Jan 13, 2008 | 07:45 AM
86v6CP's Avatar
Re: air pump bypass
thanks I searched but not those sections
Old Jan 13, 2008 | 08:17 AM
Six_Shooter's Avatar
Transmission: 5-speed/T-5
Re: air pump bypass
Is this an '86 or older? It sounds liek it is, because your post implies two seperate belts.
If it is this dual belt set-up it's real easy to bypass the A.I.R. pump by use of a shorter belt.
Glowsock
Jul 24, 2025 03:15 PM
stalkier
Dec 6, 2015 11:25 PM
TheExaminer
Aug 26, 2015 04:59 PM
beachrodder
Aug 25, 2015 08:05 AM
mcquigg
Aug 13, 2015 02:26 PM
