stalls when i hit the breaks
Old Mar 23, 2008 | 11:00 AM
dunnellon86's Avatar
Car: 89 firebird
Engine: 2.8 mpfi
Axle/Gears: stock
my cars bees stalling a lot latly code 34 so i got a new MAF nuthing but i noticed that it will only stall when hot and is is less lickley to stall if the car is in neutral and i also noticed that the harder i press on the break the more eratic the idle intill it stalls eny suggestions?
Old Mar 23, 2008 | 03:04 PM
Drew's Avatar
Re: stalls when i hit the breaks
Yeah, it sounds like an IAC problem. First and foremost, pull the IAC valve and clean the pintle assembly with a toothbrush and carb cleaner. Then clean the iac passages in the throttle body till they're spotless. Hold the throttle valve open and clean the back side of the throttle blade, and the throttle body behind the blade. This is regular maintenance for EFI cars. In stock form the EGR system recirculates exhaust into the intake and eventually you'll get a residue on everything. When it gets really bad the pintle can't move freely and the passages get gooped up and the IAC can't get enough air into the engine to keep it from dying.
Old Mar 25, 2008 | 08:26 PM
2_point8_boy's Avatar
Car: 1988 Camaro RS
Engine: 2.8L of Raw POWER!!!
Transmission: Stick Shift
Axle/Gears: 3.42's
Actually sounds like a brkae booster gone bad. if you can step on the brake and cause erratic idling, then it's causing a vacuum leak that is affecting engine performance.
Old Mar 25, 2008 | 09:30 PM
Car: 89 firebird
Engine: 2.8 mpfi
Axle/Gears: stock
ill look at the IAC tommrow
and i dont think its the break booster it only stalls when in drive or reverse if i pop it into neutral when i stop it doesent stall
Old Mar 25, 2008 | 10:08 PM
XxXChrisGXxX's Avatar
Car: 1987 Chevrolet Camaro
Engine: 2.8L V6 MPFI
Axle/Gears: 10 Bolt
ah the good ole code 34, mine was solved believe it or not by removing the MAF connector removing the back plate on the connector pulling up and out on all three wires crimping them closer together with a pair of plyers, or if you have the 15 bucks go buy a new MAF connector soldier the new wires up hot glue the piece for water proof protection and wallaaaaaaaaa for my problem you could try that just throwing my senses in this, had the same trouble at first, fixed the MAF and realized i got a front leaking hose as we'll i believe currently working on that problem.
Old Mar 27, 2008 | 07:45 AM
Car: 89 firebird
Engine: 2.8 mpfi
Axle/Gears: stock
ill give it a try hopfully it works but do you know if the car is running and i unplug the MAF shold the car keep running? when i unplug mine it keeps on going al it relly does is put the ses light on
Old Mar 28, 2008 | 12:25 AM
Drew's Avatar
I've never heard of a break booster ever failing in one of these cars.
Try disconnecting your TCC solenoid. There are two wiring plugs on your transmission. One on the tailshaft for the speedometer, and the other on the side of housing above the pan for the TCC solenoid. Disconnect it and see if the problem goes away. If it does get a new solenoid at the parts store and swap it in. If you leave it disconnected and continue driving the car, your gas mileage will go to hell, and eventually you'll burn up the converter and/or the transmission. And, they go out ALL THE TIME. Very common failure, that will cause the problem you're describing.
Oh yeah, the symptoms in the other thread you created... Same thing. It could potentially be the switch on the brake pedal too, since it trips the TCC solenoid.
Old Mar 28, 2008 | 07:39 PM
Car: 89 firebird
Engine: 2.8 mpfi
Axle/Gears: stock
got eny pics of this thing man ill be glad if its fixed thanks
Old Mar 28, 2008 | 11:34 PM
Drew's Avatar
No pics sorry. Just jack up the car, put it on stands and look at the transmission. You can't miss the TCC plug.
Old Mar 29, 2008 | 05:23 AM
Car: 89 firebird
Engine: 2.8 mpfi
Axle/Gears: stock
ok thanks ill do it later just got off work man i hate third shift ill let ya know
Old Mar 30, 2008 | 02:44 PM
Car: 89 firebird
Engine: 2.8 mpfi
Axle/Gears: stock
ok well i changed the TCC today no change still the same i orderd the stop light switch it will be in tommrow ill let ya know what happens
Old Apr 1, 2008 | 10:15 PM
Car: 89 firebird
Engine: 2.8 mpfi
Axle/Gears: stock
well stop light switch dident hlp still stalls and slill sluggish off the line
dont know what it could be here is what i have changed out
MAF
fuel filter
plugs
wires
cap & roter
transmition filter
TCC
coil
ingition moduel
PCV
thats all i can think of off the top of my head
Old Apr 2, 2008 | 03:42 AM
Drew's Avatar
What part of troubleshooting the problem, didn't you understand? Throwing parts at a problem does nothing except drain your wallet and support the local autoparts store.
Old Apr 3, 2008 | 07:40 AM
Car: 89 firebird
Engine: 2.8 mpfi
Axle/Gears: stock
most of the things i have replaced were routeen mainenence
i just listed them to weed out eny posebilitys fore some one who could help me
Old Apr 3, 2008 | 09:59 AM
Axle/Gears: 10 Bolt
i had the same exact problem if your going to throw money at it buy the 15 buck MAF connector and replace that splice the wires, soldier them after connecting them and even throw some hot glue over them for weatherproofing or shrink wrap it, that should do it, since you've tried so many other things unless its a vacuum leak, i had to really tweak with my MAF connector and finally got it correct and it hasn't ****ed up in what 3 weeks so far
Old Apr 3, 2008 | 10:27 AM
calamitascamaro's Avatar
Car: 1992 RS 6spd
Engine: Carbed 357c.i.
Transmission: Built T56
Axle/Gears: Soon to be Strange S60
Read this whole thing and well, in my head I keep wanting to say Vacuum leak as well. Get an eye dropper and a marker that reacts to UV light. Open the marker and get the fluid out of the dropper and squeeze it into a vacuum line, (not a whole lot) and get a black light (home depot) and an extension cord, plug it in and see where it glows lol. Hey if thats not the problem at least you'll know if you have any vacuum leaks to fix.
Old Apr 3, 2008 | 03:32 PM
Car: 89 firebird
Engine: 2.8 mpfi
Axle/Gears: stock
ok so it could be a vac leak ill look into testing it what about EGR its been stalling when i take my foot off the gas but only if its at low RPMs also if i sitwith the car in park and press the gas and hold a steady lets say 3000 RPMs and then let off is stalls
thanks
Old Apr 3, 2008 | 04:25 PM
bmxerboi221's Avatar
Car: 1988 Firebird
Engine: soon to be 3.4/3400
Not sure if this would cause it but make sure you put the fuel filter on the right way... and clean the throttle body reall good, just my . Hope you figure out the problem soon I hate not knowing what wrong with my car drives me crazy
Old Apr 4, 2008 | 08:10 PM
Car: 89 firebird
Engine: 2.8 mpfi
Axle/Gears: stock
ok well now i feel like a retard but i think i solved my problem looking over the car today i noticed that there was a small crack in the air intake tube right past the MAF and i guess it opens up sometimes and stalls out thew car going to work now and well see if that was it thanks for all the help
Grant2k
Apr 4, 2016 08:21 AM
80smetalfan
Sep 22, 2015 02:55 PM
amcnellis
Sep 16, 2015 04:16 PM
rjcme
Sep 5, 2015 01:23 PM
