Port Mod for MPFI
Old May 19, 2008 | 01:06 PM
92camarorv6's Avatar
Car: 92 camaro rs
Engine: 3.4v6 sc
Axle/Gears: 9 bolt 3.73s
Port Mod for MPFI
For those that want to use an EBL Flash system with their high performance multi-port fuel injection can now have the injectors firing in batch mode. The Port Mod changes the injector firing to once per engine revolution and is available for either a 6 or 8 cylinder engine (4 cylinder engines do not require the Port Mod).
The installation of this modification needs to be done here at Dynamic EFI. It is a small 1" x 1" PCB that is installed into the ECM.
The Port Mod option is only available in conjunction with the EBL Flash system
help me out sennd mile to bettynorman1@juno.com
Old May 19, 2008 | 01:41 PM
project89's Avatar
Re: Port Mod for MPFI
the stock ecm is batch fire
Old May 22, 2008 | 01:10 PM
Car: 92 camaro rs
Engine: 3.4v6 sc
more info pleas
Old May 22, 2008 | 01:35 PM
project89's Avatar
the stock ecu fire 3 injectors at a time alternating banks i.e left 3 fire then the right 3 fire etc
Old May 22, 2008 | 02:09 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
With the exception of the '89 TTA all 3rd gen f-body port injected engines are batch fire. This means that all injectors fire at the same time. Be it a 6 cylinder or an 8 cylinder they are batch fire. All injectors fire at the same time.
The '89 TTA is SFI.
RBob.
Old May 22, 2008 | 02:11 PM
project89's Avatar
The '89 TTA is SFI.
RBob.
opps my bad i was thinking my mega squirt again which fires l-r-l-r etc
Old May 28, 2008 | 09:55 AM
Car: 92 camaro rs
Engine: 3.4v6 sc
o cool is that bad or good
Reid Fleming
Oct 10, 2015 09:56 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
bplessy
Sep 30, 2015 12:14 PM
