Ignition Coil Test Results!
Old Jul 30, 2008 | 07:29 PM
XxXChrisGXxX's Avatar
Car: 1987 Chevrolet Camaro
Engine: 2.8L V6 MPFI
Axle/Gears: 10 Bolt
Test #1: Left upper connector slot to ignition coil ground or base i got a reading of 1. (High caliber scale)
Test #2:Left lower connector and right lower connector when the wires were steady it read zero at the lowest settings on the multimeter.
Test #3:Upper right connector to ignition coil wire mount it read about 8.85 on the highest setting.
any good? / car starts sounds fine when the 02 sensor kicks in when first started it sounds jumpy and stumbly, but im losing serious power i can't get past certain speeds (65) until awhile.
Hotrodboba400
Dec 10, 2019 07:07 PM
New2Chevy
Sep 28, 2015 12:35 AM
Nick McCardle
Sep 10, 2015 08:36 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
