just checking
Car: '92 BiRd
Engine: 3.1L
Transmission: auto
just checking
I know a 3.4 is similar to a 2.8/3.1. What I need to know is if the oil pans are the same. I kind of dont see why they wouldnt be but if not please let me know. Im in desperate need of an oil pan and looking for the easiest way to get one w/o buying new.
Car: '89 IROC-Z
Engine: LSx
Re: just checking
The RWD 3.4's out of the early 4th gens yes, they were the same 2.8/3.1 block with a different top end.
Engine: 3.4 / 5.0
Transmission: 700-R4
Axle/Gears: 3.42 / 3.42
Re: just checking
the pans will fit both the blocks, but i believe they are different. I recall something about the 3.4 pan interfering with the 2.8 / 3.1 timing cover? Not to sure on that and the clearnace of the 3rd gen crossmember.
Also, theres some kind of sensor in the 3.4 pan (at least the 95 one i got). If I recall, Napa had a fairly cheap after market pan.
Car: '89 IROC-Z
Engine: LSx
Re: just checking
I heard to stay away from the chrome oil pan (if your going aftermarket) I was told the gaskets dont fit it properly and it leaks.
Car: '92 BiRd
Engine: 3.1L
Transmission: auto
Re: just checking
Thanks guys. I found a guy with a 2.8L 2wd s-10 to give me his pan in good condition for $20(JY price around here). I already researched it and everywhere I go the part numbers are the same as a 'bird so I dont imagine it matters.
Car: 13 Ram 1500/ 78 Formy
Engine: 5.7 / 7.4
Transmission: 6sp / TH350
Axle/Gears: 3.55 posi / 3.23
Re: just checking
no it doesn't. my swap dropped right in. the only issue I can see is the yr of the 2.8 (carb/fulie) and how many bolt holes for the timing cover. iirc, the fulie cars & the 3.4 have the same amount.
BumpaD82
Feb 26, 2016 02:57 PM
Numbah-1
Sep 12, 2015 08:57 PM
